HT Omega Claro soundcard
Discussion in 'Article Discussion' started by Tim S, 9 Mar 2007.
  1. cpemma
    cpemma Ecky thump
    27 Nov 2001
    'Solid aluminium' is the term in the electronics catalogues (and, no doubt, 'solid aluminum' in electronics catalogs).
    They feature an "organic semi-conductive electrolyte" (some polymer that is liquid during the earlier manufacturing stages but is converted to a solid later on) so that may have given rise to the 'solid state' term. "Ideal for high-frequency power supplies", so maybe some snake oil involved in audio applications.
    http://www.sanyo.com/industrial/electronic_components/capacitors/os_con/overview.cfm?showFileID=13
  2. DarkLord7854
    DarkLord7854 New Member
    22 Jun 2005
    I've always wanted to be able to hook up 2x 2.1 sets on a card... Think it'd work?
  3. Altron
    Altron Well-Known Member
    12 Dec 2002
    Not having the actual card in my possession, but having some experience amping high impedance cans like the HD650s, I would really doubt it. Those babies take some serious juice to purr. Most <$150 dedicated amps like the CMoy and PA2V2 can't drive them, so I think it's highly unlikely that a <$150 sound card could. I think that most people buying a card like this don't really want a beefy headphone stage, so it would be silly to cut costs in some areas (i.e. SPDIF) yet spend on a very heavy duty headamp.
  4. DarkLord7854
    22 Jun 2005
    I just did it with a cheap 15$ card :hehe:
  5. adidas
    adidas New Member
    8 Jun 2005
    Tx heaps Altron. Much appreciated! :rock:
  6. Guest-16
    Guest-16 Guest
    Oh absolutely. Extra connectors would be great and I've expressed this to HT Omega who've taken it on board and if you want something professional or pro-sumer then a separate is far better again. But then you're looking at far better speakers than £50 headphones or £60 5.1's.
    There's a dozen ways to do things and everyone enjoys their own variety of getting the best audio, I don't doubt that, and I've specifically avoided the pro-sumer discussion, because quite frankly, I just don't have the experience with it.
  7. qupada
    qupada New Member
    7 Jun 2006
    Anyone who has owned an iriver h1*0 series portable audio player will know what the solution is to the limited space s/pdif i/o problem; dual purpose jacks.
    The review didn't mention if you could use both the optical and coaxial connectors simultaneously, but under the (probably fair) assumption that you can't, shared jacks would solve the problem. It does necessitate the use of different optical cables (cf the cables used by Sony's minidisc players) but the coaxial output can be served from the same socket with a simple 3.5mm mono jack to rca adapter cable.
    On the other hand, if the intention is to use both sets of digital outputs separately, the best solution I have seen was found on a c-media 8738 pci board; extra pci backplate, ribbon cable.
  8. Jipa
    5 Feb 2004
    What's the point? HDMI-connections belong to the graphic cards eh? Atleast in my MSI 7600GT there's a HDMI-out. Then there's this cable that you have to connect to the digital output of the sound card.
  9. Gundam God
    Gundam God New Member
    9 Sep 2006
    Need HDMI or some new type of cable since s/pdif doesn't have the necessary bandwidth and i'd rather have a digital connection instead of analogue.
  10. Jipa
    5 Feb 2004
    Necessary bandwith for what purpose? :confused:
  11. Guest-16
    Guest-16 Guest
    An excellent point on dual purpose jacks! They would be good, but they'd have to include an adapter for it. I fail to see a need for the use of multiple outputs on a PC soundcard. The only thing I can assume comes close is that if you're using it for a HTPC, and even then you're looking at a serious setup.
  12. Aankhen
    Aankhen New Member
    15 Oct 2005
    Audio, I'm guessing. :)
  13. SteveyG
    SteveyG Electromodder
    23 Nov 2002
    What is the selected reference signal for these figures? (e.g. 1.228V 1kHz sinewave?) It's like saying my keyboard is on a table 4m high without saying where I'm measuring from.
    It would be useful to know this so it can be compared to other cards.
Tags: Add Tags
