News HTC dual-screen 'Courier' patented
Discussion in 'Article Discussion' started by CardJoe, 8 Apr 2010.
  1. CardJoe
    CardJoe Freelance Journalist
    3 Apr 2007
  2. Shagbag
    Shagbag All glory to the Hypnotoad!
    9 Nov 2006
    I honestly can't see how such a patent could be legally enforceable. I don't see anything innovative in it at all. It's two touchscreens. Big deal.
    People should remember: just because a patent has been issued by the patent office, it doesn't necessarily mean the law will respect it.
  3. Cupboard
    Cupboard I'm not a modder.
    30 Jan 2007
    those hinges look silly!
    A big meh from me for now
  4. Autti
    Autti What's a Dremel?
    29 Oct 2009
    I think Nintendo beat them to it.
  5. Sloth
    Sloth #yolo #swag
    29 Nov 2006
    I believe the hinges are dramatized to show how the two screens should behave in relation to each other, an actual product would probably have much more discrete hinges (like a Nintendo DS, as Autti pointed out these devices would at least look vaguely similar). Patent drawings aren't meant to be exact representations of real products, just a way of clearly and concisely explaining what specific ideas are being patented.
    All the patent talk aside, smart phones, slates, or any other device that doesn't have a dedicated keyboard just isn't something I have a use for so I'm not terribly excited, but the ability to fold shut is something I'd like to see be more common. Much like the DS compared to the PSP, this device is something I would prefer over an iPad or the HP slate because of this feature. My coat pocket, for example, isn't wide enough to hold the latter two slates yet if you folded either one in half there would be no problem. Also, there is no case or cover required to protect the screens since they are not exposed in a closed position.
  6. TWeaK
    TWeaK Minimodder
    28 Jan 2010
    Could it be that when the device is fully opened the hinges become part of the screen? Kind of looks that way to me..
  7. HourBeforeDawn
    HourBeforeDawn a.k.a KazeModz
    26 Oct 2006
    Ya well the same could be said about most of Apples Patents.... so HTC is just having to do similar to stop all of Apples BS lawsuits...
  8. DirtyH
    DirtyH What's a Dremel?
    20 Jan 2005
    Maybe, but technically its time for an update.
    Imagine this thing with the power and two screens from the HTC HD2 for example.
    That would be awesome :D
    I really hope the next Nintendo handheld will have similar high resolution screens.
  9. HourBeforeDawn
    26 Oct 2006
    Ya nintendo does for a hand held console, they patent for a dual screen cell phone.. see the difference and how thye could get away with it ;)
  10. sompo
    sompo What's a Dremel?
    6 Jun 2011
    dual screens is to much for individual usage......i think single screen is enough.
  11. wyx087
    15 Aug 2007
    if you can't run two apps side-by-side, it's useless.
    only reason to use hinged dual-screen device is for more functionality, in sacrifice of sturdiness. so the dual-screen must behave like Courier concept where two different apps can run side-by-side and stuff can be dragged between them.
    which is currently not possible using any of the mobile OS. HTC will have to sit on this for a while.
Tags: Add Tags
