HTPC HTPC Build advice
Discussion in 'Hardware' started by warrmr, 16 Aug 2012.
  1. warrmr
    warrmr What's a Dremel?
    5 Nov 2003
    Howdy guys,
    I have been inspired by this guy and have decided to undertake a similar HTPC build myself.
    The only criteria I have is that it must be as cheap as possible and do the job, I already have some of the components that are needed to do the job but im unsure about a GFX card and PSU.
    What I have,
    ECS mcp61m-m3 motherboard with onboard graphics (VGA out only)
    AMD Sempron 145,
    1GB ddr3 ram
    Assorted HDDs, Will probably buy a SSD eventually but at the mo it will be a 5400 laptop drive.
    What I think I need to purchase
    DVB-S2 freesat HD tuner card dual input
    NVidia Graphics card (GeForce 8 series) Anything aslong as it does HDMI and supports Hardware acceleration of Myth TV/XBMC
    PCI-E x16 remote riser card
    PCI-E Riser card
    PSU ?
    I already have a 400watt PSU that I could use and im pretty sure that it will be more than powerful enough but as I am doing a "Copycat" mod the PSU will not fit in the Sky box with the case. I was looking at a Pico PSU like dynamis_dk used but according to the Termaltake PSU calculator I need over 200watts and I cannot find a 250 watt Pico PSU.
    What can I do to reduce the need for a higher power PSU or should I be looking to see if a 1U server PSU will fit in the sky box along with the rest of the hardware.
  2. warrmr
    5 Nov 2003
    Well I have been doing some thinking and have decided rather than going and getting an add in graphics card just so that I can use HDMI, I have manage to find a motherboard that will take my existing Processor and RAM that has a HDMI port available to it.
    The Asrock 880GMH/USB3 looks to be a good choice and is cheaper than a new graphics card. With that in place It looks like I could get away with a 160watt or 200watt PSU
    Cheers for your help guys,.
  3. okenobi
    okenobi What's a Dremel?
    3 Nov 2009
    The TV card you need is the Black Gold 3600. It has twin DVB-S2s AND DVB-T2s.
    What case(s) are you looking at?
  4. warrmr
    5 Nov 2003
    I was looking into making a copycat mod to that linked in my first post using a white sky+ box that I have laying around. But I am now thinking it might be a little ambitious so might end up buying a small htpc case.
    That tuner looks awesome but outside of my budget, I have been looking at the BGT3595 as they seem to be going for around £60.
  5. Greentrident
    Greentrident Minimodder
    10 Jul 2009
    The silverstone milo case(from Scan) looks like the most economical htpc case that looks like "hi-fi" kit. I've got a htpc setup in an standard micro-atx case and standard geenric ATX PSU fitted but that's the weak link since its the only audible component at present.
    I have a blu-ray drive and it's connect to the surround sound via optical out but I don't use a TV tuner card- most TV I watch is on netflix, lovefilm or iPlayer!
  6. Sheiken
    Sheiken Wat?
    9 Jan 2005
    I have recently bought the Milo 03 case, and it is great for the price!
  7. warrmr
    5 Nov 2003
    @Greentrident and @Sheiken how big is the Milo ML03 case as looking at the picture it looks to be quite large as it takes a full sized PSU. How would it compare in size to say an xbox or a DVD player.
    Also the good price that I saw on Amazon for the Asrock 880GMH/USB3 is no longer avalable and I have just found out that it is a discontinued board.
    Any other recommendations for a motherboard with HDMI out.
