HTPC HTPC Build recommendations
Discussion in 'Hardware' started by happyhammer7, 13 Oct 2010.
  1. happyhammer7
    happyhammer7 What's a Dremel?
    19 Oct 2009
    Hi,
    I have never built a HTPC before but I am confident in my ability to do so. However, I am not confident in choosing the right parts for the task.
    So far, I have chosen -
    Gigabyte GA-H55M-UD2H H55 Socket 1156 VGA DVI HDMI Out 8 CHannel Audio ATX Motherboard
    intel Core i3 530 2.93GHz Socket 1156 4MB L3 Retail Box Processor
    Corsair 4GB (2x2GB) DDR3 1600MHz XMS3 Memory Kit CL7(7-8-7-20) 1.65V Unbuffered Non-ECC
    XFX HD 5770 1GB XXX Edition GDDR5 Dual DVI HDMI DisplayPort PCI-E Graphics Card
    Antec Fusion Remote Veris Black MATX Media Center Case - No PSU
    Western Digital WD20EARS 2TB Hard Drive SATAII 64MB Cache - OEM Caviar Green
    Corsair 500W CX PSU - 5x SATA 2x PCI-Express
    I already have the CD-Drive and ordered the antec fusion case, but I just want to make sure the other parts are either compatible or if there are better/cheaper alternatives that will give a similar level of performance.
    Any input is most welcome.
    thanks
  2. Jipa
    5 Feb 2004
    Looks solid to me. Are you going to also game on the HTPC? If so, the HD5770 makes sense, but if it's only for playing movies, any lower-spec (well namely the passively cooled HD5450) will do just as well.
  3. happyhammer7
    19 Oct 2009
    Yes a little, nothing too intensive but I would like to have the option to run most games over the past 5 years or so.
