HTPC HTPC cases, need good dimension information
Discussion in 'Hardware' started by Splynncryth, 17 Dec 2009.
  1. Splynncryth
    Splynncryth 0x665E3FF6,0x46CC,...
    31 Dec 2002
    Does anyone know of a good place with data on HTPC cases? I'm trying to figure out the components I want, and the case is probably going to be the big ticket item. I have not settled on a form factor, but I would like it to be roughly the size of my AV receiver which is ~17"(432mm) wide by ~6.5"(165mm) high by ~13"(330mm) deep. Beyond that, I want it to look like an AV receiver, but that's easy enough to find from the pictures. actually getting the dimensions of the case can be a little more difficult.
  2. 13eightyfour
    13eightyfour Formerly Titanium Angel
    9 Sep 2003
    The problem with HTPC cases is that, if you find one thats the right width, its bound to be too deep, and if you find one thats the perfect depth its more than likely to be too wide.
    Check out silverstones range, they have detailed specs for all their cases including dimensions.
  3. IanW
    IanW Grumpy Old Git
    2 Aug 2003
    Antec Fusion Max (which I have) looks the part but is 500 deep ( if you include the plugs for mains, video etc).
    For dimensions Anandtech have a group test of Antec's HTPC cases.
  4. 13eightyfour
    9 Sep 2003
    I have the same case, nice and easy to work in, plently of space, but your right it is a bit of beast size-wise. It makes the PS3 & 360 look tiny.
