hello all i need some help with my htpc. I've recently found out how awesome VLC is and i have two questions for you: #1. what is the best way to get my DVDs to play on VLC #2. can VLC play blueray? if so how do i get them saved as files on my hard drive? thanks you for your help Ps:i'm using xp as my os
Insert the dvd into your pc and open vlc. Hit ctrl+d and select the disk. Play. Not really, it can, but it isnt pretty.
