Small Form Factor Htpc Os
Discussion in 'Hardware' started by kill_me_quick, 18 May 2004.
  1. kill_me_quick
    kill_me_quick Big and Blue
    7 Jan 2004
    Has anyone used win XP media center addition?
    I want to run a HTPC so i was thinking of either using media center or 2000Pro with an HTPC software.
    No im not buying a prebuilt system but i can get hold of either OS.
    Thanks
  2. kill_me_quick
    7 Jan 2004
    45 views and no reply?
  3. Penrhos
    Penrhos What's a Dremel?
    23 Oct 2001
  4. ArmyAnt
    ArmyAnt What's a Dremel?
    6 May 2004
    media center is good if you get the service update, I have a M$ developer kit, all OS'es, and i dont want to support them any more than neccesary. theres a guide on the net about building a HTPC from linux, and theres an HTPC version of knoppix.
  5. woodshop
    woodshop UnSeenly
    14 Oct 2003
    yep
    this one http://mysettopbox.tv/
  6. kill_me_quick
    7 Jan 2004
    Yeah got All Os's disk 1 off a friend so I'm just burning random OS's to Cds at the moment.
    Will try the media center once i get my htpc built
    thanks guys
  7. Nath
    Nath Your appeal has already been filed.
    28 Dec 2003
    myHTPC seems pretty good and easy to use, plus you can boot up into it rather than going straight into windows *i think*. also it's free. it also seems quite popular. Clicky
    Hope this helps,
    -Nathan
  8. herbs
    herbs Nobody but us chickens
    7 May 2001
    My vote goes with myhtpc, it works well in my 2 pvr and htpc pcs.
  9. kill_me_quick
    7 Jan 2004
    I had a play with it last weekend, the problem that i didnt like about it, there is no inbuilt dvd player and you have to pay for the one that they surgest.
    I might have a go with the windows media center OS otherwise im just gonna run 2000Pro and myHTPC
