HTPC: Project1970 (completed 20. Feb)
Discussion in 'Project Logs' started by bard, 1 Jan 2005.
  1. Mr. Red
    Mr. Red Minimodder
    1 Aug 2003
    Is this what you are looking for?
    http://www2.dvigear.com/riandviadma.html
    Its a bit pricey though. I am not sure what your clearence is, but they make cables that have VGA on one end and DVI on the other. Should be able to find them around US$20.
  2. moddenmania
    moddenmania What's a Dremel?
    18 Sep 2004
    link dead
  3. CaseyBlackburn
    CaseyBlackburn Network Techie
    27 Jul 2004
    you need to copy the link text because the link goes to "http:///"
  4. automagsrock
    automagsrock What's a Dremel?
    18 Nov 2004
    Wow, this is amazing. Do you have a job as a carpenter or woddsmith because damn you are good!! :jawdrop:
    How large of a hard drive are you using for this PC for TV recording and such? I am starting a HTPC and am trying to get some numbers to play with.
  5. ZapWizard
    ZapWizard Enter the Mod Matrix
    19 Sep 2002
    Suggestions for the legs:
    Depending on how heavy the unit ends up, you could try to use copper pipes.
    With three pipes per leg it should be enough anyways.
    Polish the copper up nice, and clear-coat it to keep it shiny.
    As far as mounting it to the bottom/top plates, I am not sure, I wouldn't trust solder.
    Got a friend who can weld? (Steel pipes in that case)
  6. bard
    bard Modding isn't what it used to be
    8 Mar 2003
    Hi automagsrock. Design and woodwork are only hobbies for me. I have, however, been doing it for quite som years, so I have some experience.
    The only hard drive I have around to use in this project is a 160 GB one. With the quality I normally use for recording, I can get more than two days of television stored on it.
    I might try to find a DVI extension cable or a DVI>VGA cable then. The angled DVI adapter was a bit pricey, but we'll see..
  7. CaseyBlackburn
    27 Jul 2004
    If you are using a dvi to vga adapter i was thinking that you could plug the dvi-vga adapter into the lcd end then use a dvi cable to plug it into the back of the monitor
  8. bard
    8 Mar 2003
    Copper pipes is a good idea, but I think I want them to be grey/steel colored. (I could, of course, paint the copper). I looked at the axel rods suggested previously in the post, but the problem is that it will cost $50 just for the rods alone... I guess copper pipe is cheaper.
    I could just go to a weld shop to get the legs welded, I guess.
  9. bard
    8 Mar 2003
    I have cut the holes for the power and eject buttons (on either side of the DVD drive). This can be seen in a later pic.
    The buttons are made out of 6mm perspex, 25x25mm with two rounded corners. The rounded corners are made with a file:
    I have also added a few layers; a strip of plexi and another layer of wood after that:
    After sanding the curve smooth in the front area, I used my router to make a rounded edge:
  10. cerberus
    cerberus What's a Dremel?
    23 Sep 2003
    Simply stunning ........... thats all i can say :jawdrop:
  11. CaseyBlackburn
    27 Jul 2004
    i think it would be cooler if you put the buttons below the drive like this: (][)
  12. Wrigley1
    Wrigley1 What's a Dremel?
    5 Dec 2004
    Wow, that really is some excellent woodworking. Can't wait to see it stained.
  13. bard
    8 Mar 2003
    The painting has commenced. I have masked off the flame polished edges and the show faces of the perspex parts, and started vinyl dyeing them on the backside, just like Macroman did on his macroblack case. This gives a nice, glossy finish from the other side, and I hope the polished edges will give a nice effect too. I'm painting in light layers, and after the first layer, I could actually see finger prints form on the perspex... you can still see some marks from where I washed it with a cloth before painting. Probably won't show in the end, though.
    The perspex ready for painting:
  14. JavaDog
    JavaDog What's a Dremel?
    13 Mar 2004
    Provided that your monitor does not have a captive cable, you could always use this: Startech 6ft DVI-VGA Cable
    Same thing as an adapter, only built into the cable. :thumb:
    Amazing work so far, this is going to look great (However, I think a nice honey stain would look better, IMHO). :D
  15. bard
    8 Mar 2003
    Yeah, I'm thinking of maybe giving it an oak or honey stain instead, but the darkness of the cherry would hide any imperfections in the woodwork (not that there is any.. :worried: )
  16. Smilodon
    Smilodon The Antagonist
    25 Mar 2003
    hmm.. the dark color will actualy make any dents and such in the wood show better.
    Great work BTW" :thumb: (but you already know that ;) )
  17. bard
    8 Mar 2003
    Yeah, but there might be some tiny cracks in some of the joints. I can't see them now, as they are filled with sawdust, but when I start getting liquid on them, they might show up... Anyway, I can get the case as dark as I want using layers of stain, so it's no problem really.
  18. ZapWizard
    19 Sep 2002
    When I paint plexi on the backside I spary it slightly heavier then normal.
    I have found that the paint is pulled to any static-cling areas and can leave varried textures. This doesn't show up much using black though.
    It helps to use a anti-static cleaner first too.
  19. bard
    8 Mar 2003
    Oh, I didn't know that. I figured I'd use light layers as Macroman warned that it might crackle if it is sprayed too heavy. But this is vinyl paint, and it should be ok using heavier coats, I guess... I'll do some heavier coats tomorrow then.
  20. Anthony
    Anthony What's a Dremel?
    6 Jan 2005
    I started the samekind of mod at school, and we (me and my teacher) thought about the plexi on the top, and teacher said that No, it gets the scrathes more easier to see, if you get scrathses in your plexi... So I decided to do it from something else, but I am going to make the hole backboard from plexi!! It will be maybe more easier to revise then metal (?)... But this Idea is veeery great :D :D :D :D :D
