HTPC: Project1970 (completed 20. Feb)
Discussion in 'Project Logs' started by bard, 1 Jan 2005.
  1. antiHero
    antiHero ReliXmas time!
    19 Jan 2005
    great woodwork. great job all over. one idea for the legs u could go to an junkyard or an furniture disposal or something in this direction. maybe u find an old 70th table with nice legs. would give the whole project an original touch. anyway keep on modding :dremel:
  2. bard
    bard Modding isn't what it used to be
    8 Mar 2003
    First an update on the plexi work:
    Here's the DVD cover all shiny and ready for use:
    It's a bit hard to take a good picture of, as the reflected image becomes darker than the actual image, making it hard to find a good exposure time.
    I've finished all the spray coats on the table top as well. It turned out great. It did, however, let some light through when I held a lamp up behind it, so I went out and bought some black paint. I'm just applying this paint with a brush as it's not going to be visible anyway. These coats of black paint will also make the table top more durable, resisting scratches from below.
    If it becomes this glossy on the underside, imagine the top :D
    Now to the woodwork:
    I've sanded the whole thing with 100 and 150 grit paper. I then used a fiber cloth to make it even smoother.
    Now here comes the (in my mind) most important trick of them all when it comes to getting a smooth surface when staining and varnishing:
    If you just sand the wood and apply stain to it afterwards, the wooden fibers will start to rise, giving you a rough surface. This can't be sanded down, because that will remove most of the stain as well. Use a wet cloth and moisturize all of the wood. When this dries, the fibers will have risen equally. Just sand down the wood once more, and when you apply the stain/varnish, the wood will stay smooth.
  3. Eran
    Eran What's a Dremel?
    6 Nov 2004
    Can't wait for another update!!!! :clap:
  4. Sc0rian
    Sc0rian Here comes the farmer
    23 Feb 2003
    deffo,
    Looks great dude:)
    - S
  5. Anthony
    Anthony What's a Dremel?
    6 Jan 2005
    Looking goood, more updates!!! :hehe: :hehe:
  6. bard
    8 Mar 2003
    Thanks, people! And it's your lucky day...
    While waiting for the black paint to dry I've started on the power and eject switches.
    The switches as seen before:
    I printed the power and eject symbols on transparent adhesive film (Press-it papers really...)
    For the black to be completely opaque, I printed each symbol three times and put them on top of each other. I also added a clear layer on top, so you won't get ink on you when pressing the buttons...
    I stuck the symbols to the previously shown plexi pieces (don't mind the dust...):
    And here's the result backlit by an LED (will of course be better when I get a diffuser for the light):
  7. Franklin
    Franklin What's a Dremel?
    24 Oct 2004
    That looks good! :dremel:
  8. Acid Burn
    Acid Burn ..look but don't touch..
    14 Mar 2004
    the case looks outstanding! really clean cuts! but why did you make it so large?
  9. bard
    8 Mar 2003
    Heh, the size... I was actually going to make a case smaller than my current one. But then I decided to add those curves, and it grew a bit... I could have made it about 10cm shorter, but that would interfere with the design. Remember, it isn't a case. It's a table...
  10. noCode
    noCode What's a Dremel?
    16 Oct 2003
    I just have to say that this is so far one of my favorite mods of all times!
    It's just so beautiful!
  11. perplekks45
    perplekks45 LIKE AN ANIMAL!
    9 May 2004
    I see a lot of skill... :hip:
  12. greywolf
    greywolf What's a Dremel?
    15 Oct 2004
    This is a very classy mod. Really like the woodwork.
    Have you found the legs you want yet? Seems I've seen those around some where...I'll look and post back if I find them.
    Really nice project!
  13. [Tom]
    [Tom] Minimodder
    10 Dec 2003
    How about Woodfit for the legs....they have some pretty stylish ones on there- especially the s/steel tapered on the 2nd page.
  14. greywolf
    15 Oct 2004
    Well, I found a couple of sources, but they are not exactly what your looking for:
    US source:
    Closet Masters
    These guys have something very similar:
    B&Q
    I think these legs would make a good alternative:
    hafele
    I hope these sources help!
  15. bard
    8 Mar 2003
    Thanks for the links, but those are way too expensive to be pre-made :worried: (I like making things on my own, even though it's usually cheaper to just buy it..)
    I've found a place where I can buy aluminum tubing quite cheap, so I'll try to fabricate a leg from that. I'll let you know how it goes.
    I haven't had much time to work on this project lately, but I think I will have some time on Friday.
  16. CaseyBlackburn
    CaseyBlackburn Network Techie
    27 Jul 2004
    cool hope the work comes out ok
  17. Lord_A
    Lord_A Boom baby!
    23 Mar 2002
    Great project once again bard, excellent ideas and skills in this one too.
    Very good idea btw, hope the rest of the work goes well :dremel:
  18. bard
    8 Mar 2003
    Small update:
    This is how it looks at the moment. The whole thing has been stained and given four coats of glossy varnish (with polishing in between).
    The stain is a mixture of mahogany and cherry, with some added water so it wouldn't be so dark. The stain is applied in two coats, and together with the polyurethane varnish it gives the wood a nice shine, almost like stained birch (it is really pine).
    The black table top turned out just as I hoped for. Maybe even a bit too shiny... :worried:
    I have done som experimenting with aluminum pipes, but I haven't taken any pics of it yet..
  19. CaseyBlackburn
    27 Jul 2004
    lookin good
    may i ask what it is sitting on right now it seems like the frame from the desk we have at my school
  20. MAD_OCM
    MAD_OCM What's a Dremel?
    12 Feb 2005
    looks fantastic,
    im building a wooden HTPC case myself, nothing like your though.
    its a nice change to be working with computers and wood.
