HTPC: Project1970 (completed 20. Feb)
Discussion in 'Project Logs' started by bard, 1 Jan 2005.
  1. bard
    bard Modding isn't what it used to be
    8 Mar 2003
    Gentlemen, and the occasional lady, the 1970 HTPC project is herewith complete!
    You may notice that the LED stripe around the top is not lit. I might add some LEDs to it later.
    The color I chose for the buttons is red. Blue wasn't invented in 1970, you know... :worried:
    The hardware in place. As you can see, it's quite a tight fit, despite all the open space at either side of it.. The optical drive barely fit behind the graphics card (I didn't think of that...), so when I exchange it for a DVD-burner, I have to make sure it isn't much longer than the CDRW I have now.
    A full shot of the table. A yellow room with fluorescent light isn't the best environment in which to photograph, so I might return with some better pictures later on.
    The legs have been anchored to the table using some 45 degree struts on the underside (not visible in pics).
    The top plexi is fastened with velcro, which makes it really easy to take off for inspection or extra cooling.
    With the top on, the CPU temp ranges around 45-50 degrees (with some load). This is when the intake fans run at minimum speed, though.
    Comments and thoughts are welcome :)
  2. koola
    koola Minimodder
    11 Jul 2004
    WOW - That is a really nice piece of tech furniture. Top marks to ya :thumb:
  3. CaseyBlackburn
    CaseyBlackburn Network Techie
    27 Jul 2004
    i wanna se it with the lcd monitor hooked up above it and working in all its beatiful glory
  4. bard
    8 Mar 2003
    Hey casey. Then you'll have to wait for the photoshoot. Right now its main function is to be my desktop computer (and HTPC, connected to a TV and stereo another place in the room)
  5. CaseyBlackburn
    27 Jul 2004
    well i guess i can wait
  6. <A88>
    <A88> Trust the Computer
    10 Jan 2004
    How strange, I haven't seen this one before! Well, it looks really smart nonetheless, the buttons look cool :)
    <A88>
  7. ZapWizard
    ZapWizard Enter the Mod Matrix
    19 Sep 2002
    Great to see it finished.
    Make sure when you get that DVD burner that it has a black tray.
    Sony's are normaly short drives, at least their DVD and DVD/CDRW combo's are.
  8. bard
    8 Mar 2003
    I'll try to get a black tray (and black bezel, as I don't want to take it off). However, It's not crucial, as it will hardly ever be open.
    Plextor burners are also quite short. I can't have it a much longer than it is today (I could switch to a 90 degree molex and gain 1cm, though.)
  9. KodiakStar
    KodiakStar What's a Dremel?
    3 Jan 2005
    Great Job Bard!
  10. Klekkus
    Klekkus What's a Dremel?
    5 Nov 2005
    WOW looks very nice, but my friend means the oposite. He means it looks like a boat with feets :p
    One of the best HTPC I have seen in a very long time ;) very original design. Something else then a stereo case ;) like every HTPC looks like.
  11. LuitvD
    LuitvD What's a Dremel?
    13 Aug 2006
    one of those looks quite much like your original design of the feet :) cost only a couple of bucks each
  12. yahooadam
    yahooadam <span style="color:#f00;font-weight:bold">Ultra cs
    21 Mar 2006
    man that looks really slick, really fantastic job man :thumb:
