HTPC htpc sound and graphics....
Discussion in 'Hardware' started by Noob4ever, 1 Nov 2008.
  1. Noob4ever
    Noob4ever always learning
    14 Oct 2007
    Now I'm thinking of building an htpc, and having it dual as a home server, my biggest question really is, what kind of graphics card should I use to hook up to my tv, and even more importantly, how do i hook up the sound? This is probably a stupid question but oh well, gpu's dont usually output sound :D
  2. Guest-16
    Guest-16 Guest
    What TV do you have and will it be hooked up directly or through a receiver first?
    What kind of video do you play?
    What's your budget?
  3. EnglishLion
    EnglishLion working for the good of mankind...
    2 May 2008
    There are some very good motherboards these days with integrated 8200 graphics. These support HD and I should imagine most will support a connection to a SDTV through use of an adapter on a VGA port. If you use integrated gpu and sound then you can make the htpc much smaller and quieter, ie living room friendly.
    It all really depends on what you are hooking up to and what qualities you would like. I have my htpc outputting through s-video to an old SD widescreen CRT TV and the sound is just a 2ch feed - both connect at the TV end through a SCART adapter. If I had the money I'd love to go HD on a 32" LCD and get a good set of multi input 5.1 speakers.
  4. bigsharn
    bigsharn Officially demotivated
    9 May 2008
    If you really need a sound card and GPU I'd go for the Asus Xonar II and Asus 9400GT respectively, purely because the latter is silent and Asus soundcards seem to be popular at the moment
  5. Noob4ever
    14 Oct 2007
    well I have a small crt tv at the moment, will be stepping upto a 32" lcd in the future.
    I mostly play tv shows and movies through the computer, since I'm never around when its on tv, and budget is what I make it, I'd prefer to keep it under 1500 usd, but thats negotiable :D
    Also, it will most likely be hooked up through my comcast box first, but I can go either way with that as well.
    Thanks guys, I will look into those mobo's at the asus gear.
  6. bigsharn
    9 May 2008
    Well I've got a 32" HD LCD and my ATI 9700 mobile graphics does me:p
  7. Neoki
    Neoki Minimodder
    26 Oct 2004
    Use the xfi titanium fatality its good
  8. mm vr
    mm vr The cheesecake is a lie
    18 Nov 2007
    An Asus Xonar HDAV1.3 would be insteresting. Dunno how useful it'd be or if it has a ridiculous price, though.
