Networks hub ! servers ! routers
Discussion in 'Hardware' started by ComputerKing, 29 Dec 2006.
  1. ComputerKing
    8 Sep 2006
    Hello
    I have 2 network Q
    1- I have Router With 4 Line out FOr each Pc ,,,,,,can I take 1 Line And put it With 8 Ports Line !!!!
    2- MY dad office , They have big ass server They have alot of hubs there ,, SO each office have 1 line for internet and sharing ! so If my dad put a small 4 port or 8 hub on this line and from this hub , make lines for teh office !!
    SO This will work , If yes I need to know
    Thanks Body :D bye , CK
  2. Glider
    Glider /dev/null
    2 Aug 2005
    Yes you can, but bear in mind, if you connect 2 switches (like you are doing now) you might need a crossed cable. Newer switches support the use of straight ones, but check first!
    Come again? You just want to share internet access or what?
  3. ComputerKing
    8 Sep 2006
    yes share internet access , MAn you cool you can understand me Thank you
    Edit : HOW !!!
  4. Buzzons
    Buzzons Minimodder
    21 Jul 2005
    adsl line -> router -> switch -> computers
  5. DougEdey
    5 Jul 2005
    Or it may be
    DSL Line -> Router -> Switches with crossover -> computers straight through
  6. ComputerKing
    8 Sep 2006
    OK thank you my body , Glider , Buzzons , DougEdey
    thanks for your help guys its help me out now I will buy the hub for my dad office
    I hope it works :D thankssss
    bye > CK
