Modding Huge Enermax Psu Problem
Discussion in 'Modding' started by bee2643, 23 Mar 2002.
  1. bee2643
    bee2643 What's a Dremel?
    7 Mar 2002
    I just bought an Enermax Whisper EG365P-VE(FC) PSU...the 92mm fan on the bottom of this psu was my main reason for buying it, i had gone through 3 other psus with my computer, each one i modded to have an extra 92 or 120mm fan in the bottom to vent.
    this particular Enermax PSU's fan is temp controlled by a temperature probe with roughly 4" of slack to it
    this fan has a 7000rpm capability, but runs at 2295rpm because the temp probe is ****ing with my computer
    i need full rpm, to fix that, u cut off the temp probe (so enermax sais) but doing this will void my 2year warranty
    how can i remove this temp probe unnoticeably or is ther any other way to make it spin full opur rpm?
    my comp is liquid cooled so i cant shove it in the heatsink, and the temp probe only has 4" of wire on it, what good is that? i have no maneuverability for this wire by no means
    HELP ME
  2. Haddy
    Haddy World Domination
    22 Jan 2002
    send that pos back and get an antec...or one of these
  3. UnLoadeD
    UnLoadeD What's a Dremel?
    2 Jan 2002
    shove it next to one of the heatsinks IN the psu, that should do it.
  4. bee2643
    7 Mar 2002
    no cuz the heatsinks are right above the fan
