Hi there. My dad will be getting me 2 old cases from work and i am going to make them into JET pc's. I remember seeing a mod around where they bondoed the whole front up and had some massive aeroplane style intakes. Has anybody got a link or an equivilant so i can see how to go about it. 'I've tried looking in the project log forums for it but i cant find it. VisualAid-
i was thinking small intakes 120mm or 80mm looking like a turbine engine. Not a pc in a turbine engine!
yeah jesse thats what i plan on doing. I hope . gonna take front panel bondo the whole thing (maybe). Cut a drive whole in the middle then cut 2 huge 120mm intakes top and bottom. With big tunnels going into the case. i've seen 1 whole on the front that looked like a plane cant find it though.
Nothing wrong w/ a PC in a turbine... You maybe refering to Mnpctech's Excaliber...he has 2 turbine style fans on his front bezel....altho he had to connect 2 panels together inorder to fit them...but he's a big fan of the turbine style fans... Heres a link from his website that tells how to make those.. 120MM Turbine I'd shoot off an email to him if you have any major questions...if not..good luck man...put it up in the Project Logs so we can all see!
http://forums.bit-tech.net/showthread.php?t=51357 I didi something similar ^^ Also "jet" intakes. And yes, lots of bondo!!
i am really liking that idea with the huge fan intakes i think i am going to have to build something from that idea but u know how modding is it is not really modding if some one did it before it is only coping
yeah. I'm finding a way to make my 1 unique . btw. Were do you guys get your bondo from B&Q and places?
