Overclocking [hwbot] Super Pi 1M Rankings!
Discussion in 'Hardware' started by Eliminos, 17 Feb 2006.
  1. Stigggeh
    Stigggeh What's a Dremel?
    2 Aug 2005
    top two... see post 37 intel 4tw :naughty:
  2. Soul__Assasin
    Soul__Assasin What's a Dremel?
    21 Oct 2004
    I've also taken my first steps in overclocking and I am proud of my first tests...
    Specs:
    -Dfi 855GME-MGF
    -Dotham 730(1.6GHZ) @ 2.334Ghz
    -2gig OCZ Twin matched pair @ 2.5 3 3 6 194.5Mhz
    super Pi 1m in 35sec
    good for a 17th place in the global ranking
    [hwbot] Soul Assasin - 35.00s - Dotham 730(1.6GHZ) @ 2.334Ghz / 2gig OCZ Twin matched pair pc 3200 @ 2.5 3 3 6 194.5Mhz [/hwbot]
  3. Tim S
    Tim S OG
    8 Nov 2001
    [hwbot] bigz - 27.461(s) - AMD Athlon 64 FX-57 @ 3063MHz / 1GB PC5000 @ 278.5MHz 2.5-3-3-10-1T [/hwbot]
  4. MR BUNGLE
    MR BUNGLE Shoddymodder
    19 May 2003
    Phew - Knew I could get it into the 30's (only just)
    [hwbot] Mr Bungle - 39.798 - Athlon XP @ 2567 (223x11.5) 2-3-3-11 Maze4[/hwbot]
  5. Eliminos
    Eliminos What's a Dremel?
    2 May 2005
    [hwbot] 31.848 - AMD Athlon X2 3800+ @ 2.75GHz / G.Skill HZ 1T 250MHz 3-4-3-8 [/hwbot]
  6. bleedmarshall
    bleedmarshall What's a Dremel?
    9 Dec 2005
    [hwbot] 27.328s - AMD Opteron 148 @ 3.212Hz / G.Skill ZX 1T 214.2MHz 2.5-3-2-5 [/hwbot]
  7. DeviateXIII
    DeviateXIII What's a Dremel?
    29 Aug 2005
    Withdrawn
  8. TMM
    TMM Modder
    12 Jan 2004
  9. Shadowed_fury
    Shadowed_fury Minimodder
    21 Nov 2003
    [hwbot] Shadowed_fury - 30.281s - Opteron 144 @ 2.880GHz - Gainward 7800GT @ 515/1215 - Corsair 3500BH5 @ 217MHz 2-2-2-6 1T 3.2V [/hwbot]
  10. FIBRE+
    FIBRE+ Minimodder
    27 Feb 2005
    FIBRE+ - 30.605s - A64 X2 3800 @ 2.8GHz (1.5v) - XFX 7900GT @ 540/1600 - 1gig OCZ Platinum PC4200 @ 280MHz 2.5-3-3-6 1T (2.8v)
    Not bad, but I think i've got a bit more room to play with :)
  11. Shadowed_fury
    21 Nov 2003
    Not bad! Stop it though, your cutting it close to me :D
  12. FIBRE+
    FIBRE+ Minimodder
    27 Feb 2005
    lol, it was accident, honest :p
    I dunno if I can get much more, I couldnt get 2.8 before but ive got a new case so have been able to get some airflow now. 3x 120mm at the front, 120mm on the cpu and 120mm exhaust (fairly quiet still)...
    Idle temps are... cpu: 29oC, mobo: 30oC, gfx: 40oC (at above speeds) :)
  13. Shadowed_fury
    21 Nov 2003
    Might wanna try 1.55v, could get a bit more outta it. Every Mhz counts ;)
    Is that all on Air cooling too?
  14. FIBRE+
    FIBRE+ Minimodder
    27 Feb 2005
    It was a pretty crude overclocking session, just wack it up, little tweak then away we go. I need to do some proper tweaking tomorrow...
    Yer, all air, Thermalright XP-120 YS-Tech on the cpu and some cheap case fans elsewhere :)
    Edit:\Cant get 1.55v
  15. Shadowed_fury
    21 Nov 2003
    Sounds like the usual fun must-get-silly-1mPI-outta-this-chip session. :)
    Was gonna suggest 1.6, but since your on Air, I'm not sure. :X
  16. FIBRE+
    FIBRE+ Minimodder
    27 Feb 2005
    LOL, just about... :p
    [hwbot] FIBRE+ - 30.255s - A64 X2 3800 @ 2841GHz (1.5v) - XFX 7900GT @ 540/1600 - 1gig OCZ Platinum PC4200 @ 284MHz 2.5-3-3-6 1T (2.85v) [/hwbot]
    Let the battle commence Shadowed_fury :naughty: (I think im spent tbh, maybe some ram tweaking)
  17. teamtd11
    teamtd11 *Custom User Title*
    31 Aug 2005
    [hwbot] teamtd11 - 30.453 seconds - AMD Athlon 64 3700 SD @ 2970.8mhz / 1gb PC3200 ram @ 212.2mhz 3.3.3.6 [/hwbot]
    edit: my ram is holding my time back soooooo much :waah:
  18. Shadowed_fury
    21 Nov 2003
    :D Grr you!
    Just you wait for next week. TCCD is the newcomer. I'll thrash that score :D
  19. Highland3r
    Highland3r Minimodder
    25 Jul 2003
    You'd better.... :p
  20. FIBRE+
    FIBRE+ Minimodder
    27 Feb 2005
