Cooling Hydor L30 running HOT
Discussion in 'Hardware' started by 2800@2.5ghz, 3 Jun 2005.
  1. 2800@2.5ghz
    2800@2.5ghz What's a Dremel?
    23 Mar 2005
    are these pumps supposed to run hot(as in almost too hot to touch in some places), i have a friend who is using one in his setup atm and it gets really hot and he is concerned it is adding too much heat to his loop?
  2. Risky
    Risky Modder
    10 Sep 2001
    If the heat was going into the loop they wouldn't get hot!
    The pump is rated about 23W so it may well warm up. If its in the path of the rad fan then that't good for pump reliability.
  3. 2800@2.5ghz
    23 Mar 2005
    the pump is rated at 27W, but i have an eheim and that gets a little warm, he was just worried that there was something wrong with the pump becasue it was a bit hot
