Case Mod - Complete ⭐ HYDRA SLIM DESK AUTOBOT =I.E.M.=
Discussion in 'Project Logs' started by warboy, 6 Jan 2020.
  1. warboy
    warboy Insane modder
    24 Nov 2011
    Happy New Year to all!
    New start with a custom PC based on the Hydra slim desk (https://www.hydra-shop.com/product/slimdesk/)
    This time I will be inspired by my favorite Bumblebee Autobot.
    It will be partially painted yellow, and airbrush details will be added.
    With the help of 3d printing I will add details inside.
    now the slimdesk
  2. warboy
    24 Nov 2011
    After sanding, I painted with an epoxy primer and then colored yellow.
  3. warboy
    24 Nov 2011
    I designed the support for the SSDs which incorporates some details of the LS3 engine
    After I printed the supports with 3D printing and I will add a plexy panel
    ifohancroft likes this.
  4. Sa mod pc design
    Sa mod pc design Minimodder
    7 May 2019
  5. warboy
    24 Nov 2011
    YEA!!
  6. warboy
    24 Nov 2011
    In the meantime, as work progresses, here is the chair chosen for the desk:
    Sharkoon Elbrus 3
  7. Sa mod pc design
    7 May 2019
    I can’t wait to be ready... The master is at work
    warboy likes this.
  8. warboy
    24 Nov 2011
    Many thanks bro ;)
  9. BigShadow
    BigShadow What's a Dremel?
    10 Feb 2020
    I want to see this when completed, good luck on this!!
  10. Diletta Graziosi
    Diletta Graziosi What's a Dremel?
    27 Feb 2020
    for sure the airbrush job will be a master piece
    warboy likes this.
  11. Jangalit
    Jangalit What's a Dremel?
    28 Feb 2020
    I love the color scheme
  12. Diletta Graziosi
    27 Feb 2020
    and you can be sure that it will be a super good job, Warboy is the godfather of airbrushing
  13. warboy
    24 Nov 2011
    THANKS Bro! prepare the radiators
  14. warboy
    24 Nov 2011
    Alphacool Eisfach - Single Laing D5
    Alphacool Eiszapfen 16mm HardTube union nut modding pack 6 - blue
  15. warboy
    24 Nov 2011
  16. warboy
    24 Nov 2011
  17. warboy
    24 Nov 2011
    Alphacool Eisblock XPX CPU - Intel/AMD - titan grey + Alphacool Eisblock XPX CPU modding kit - blue
  18. warboy
    24 Nov 2011
  19. warboy
    24 Nov 2011
  20. warboy
    24 Nov 2011
    a bit of NO5 :)
    and I use the SCORPIO to fill the system
