Scratch Build – Complete Hyper Case DM-01
Discussion in 'Project Logs' started by Defyant Mods, 14 Mar 2020.
  1. censored_Prometheus_
    censored_Prometheus_ Minimodder
    26 Mar 2019
  2. Cheapskate
    13 May 2007
    I love what you do. Keep doing it. :D
    Defyant Mods likes this.
  3. Defyant Mods
    Defyant Mods Multimodder
    14 Sep 2004
    Todays little effort was about 2 lines! and not the ones that make me happy...
    After a bit more of a sand and now some black shadow you can see that the left side has a small but very noticeable bow , creating a low spot. No amount of sanding is ganna fix this....The right side is worse as the whole side is warped and low.
    As mentioned before the panels are heat bent and this gives a rounded edge and for the look i want, i'm after a sharp edge.
    [​IMG] [​IMG]
    Ive started with the right side, the larger area to work on.
    The flat edge of the ruler shows the gap. This is low and will need to be filled.
    A quick pass with some light weight bondo and a ruff sand and the magic line is starting to show.
    Still a few spots to work on but there's a proper shard line now.
    Another layer of bondo and light sand and pretty much done for this side. A sharp clean straight line.
    Left side tomorrow :)
  4. Defyant Mods
    14 Sep 2004
    Today's effort was working on the top vent modules.
    I wanted a design that was modular would actually breath and work with the rest of theme. i'll make a second set from mesh and decide later what one works best.
    [​IMG] [​IMG] [​IMG]
    I may change the colour to silver, but will wait and see how the black contrasts with the gunmetal grey of the case.
  5. Cheapskate
    13 May 2007
    Louvers! Finally! :lol: I knew you couldn't resist the strong mental wave I was sending your way silently urging you to make them.
  6. Falqoon
    Falqoon Minimodder
    13 May 2013
    Coming along really nice. I really like the shape you've made!
    pccustom and Defyant Mods like this.
  7. Defyant Mods
    14 Sep 2004
    Small update as we head into the long Easter weekend.
    Decided to add some active cooling, where i'll be heading heat is going to be a factor. I can always remove if i decide to try passive again.
  8. Cheapskate
    13 May 2007
    She's a chunky one. :D
    I'm surprised you didn't make two brackets to mount to the threaded rods instead.
  9. censored_Prometheus_
    26 Mar 2019
    I don 't even know what makes me happy, your mod or the look of your workshop?:dremel::thumb::thumb::thumb:
  10. Defyant Mods
    14 Sep 2004
    Sure is! im not used to working on such a big scale :p but it's nice to have the freedom for a change :)
    Attaching to the bars was def the first choice but i decided that i wanted the front grill to "flip down" i wont be running any fine mesh so being able to drop the front for qik fan cleaning will be a bonus.
    Cheers Mate tyvm :thumb: i had a big spazz this weekend and had a massive clean out, decided to go for the "minimalist clean look this time :D
    This is prolly the 3rd go ive had at making this front panel...... the first one was a all flat front..... it looked nice .... but "blunt" like Cheap's said before "Chunky"!
    So i had a go at tapering the outer 4 or 5 blades.... to sorta look like side vents... it's hard to see with just the frosted clear but i'm hoping to get some paint on them through the week and post it up.
    [​IMG] [​IMG]
  11. idpcmods
    idpcmods Minimodder
    30 Jun 2015
    Loving this build man the acrylic work is on point ❤️
    Defyant Mods and TerHorstCustoms like this.
  12. TerHorstCustoms
    TerHorstCustoms Minimodder
    29 Jan 2020
    This describes its perfect!
  13. Cheapskate
    13 May 2007
    Staggered louvers are the way to go. :D
    Defyant Mods and idpcmods like this.
  14. Dot_Kappa
    Dot_Kappa 100% Puppet
    23 Mar 2006
    Top vent modules is my favourite part right now. :thumb:
    Are you going to paint the front blades with the same color ?
  15. Defyant Mods
    14 Sep 2004
    I was thinking black for the front grill as well :D the rest of the case will be metallic grey with maybe a few silver accents with grey tinted plex side windows
    kim likes this.
  16. pccustom
    pccustom Multimodder
    12 Jul 2017
    great work!!
  17. Defyant Mods
    14 Sep 2004
    Cheers pcc :D again thanks for the inspiration :rock:
    I wanted a rear boxed type shroud to mount the fans too! and to add some looks.
    The PSU side is a little different and still needs 2 more sections added (tomorrow)
    [​IMG] [​IMG]
    A slider system will allow to attach and i'll decide on a clip system or screws to hold in place.
    [​IMG] [​IMG]
    This will help a little extra air to the PSU
    The fans can be mounted internal or external
  18. Cheapskate
    13 May 2007
    The like button only works once...:(
    That bottom pic is such a great shape. It's very UN-square. :thumb: Keep going in this direction, please.
  19. Defyant Mods
    14 Sep 2004
    Thanks Cheaps :thumb:
    Today was back to the work of sanding paint and putty...... All the time consuming stuff that's not a lotta fun.
    First up was to finish off the PSU side of the fan duct a bit more shaping and more sanding....
    [​IMG] [​IMG]
    Ruff as guts for now but done. This should help get a little air to the psu.
    [​IMG] [​IMG]
    Add some contours to both sides then off for some primer....
    [​IMG] [​IMG]
    It ain't pretty but have faith :D
    Faith comes in the form of putty :D
    While i was in the mood to putty i thought i put some love into the roof !
    Look at that line :naughty:
    Few spots that spray putty just wont fill.... so putty time.
    [​IMG] [​IMG]
    LOL looks like an old car i used to drive :p
  20. Cheapskate
    13 May 2007
    Looks I a car I used to drive too. :lol: My older brother must have put $200 of bondo on the front fender, and never shaped it. I went out and found a new fender for it instead.
