Scratch Build – Complete Hyper Case DM-01
Discussion in 'Project Logs' started by Defyant Mods, 14 Mar 2020.
  1. Defyant Mods
    Defyant Mods Multimodder
    14 Sep 2004
    I have been modding! just not updating soz :D
    The back of the case has been like the front.... a bit for me to get my head around... but after a few different tries i think im happy with this.
    The hardest part was keeping the rounded corners all the way through the section. This is still early days and a fair bit to go. Still need to add the GPU hole.
    [​IMG] [​IMG]
    And some random stuff that will end up in the bin :p
    [​IMG] [​IMG]
    MADPC, Toru, Cheapskate and 4 others like this.
  2. Canardwc
    Canardwc @French_fab_factorie
    22 Sep 2011
    I do not know exactly Where you're going to, but I like what you're doing :happy:
    Nice plexi job !!
    Defyant Mods likes this.
  3. Defyant Mods
    14 Sep 2004
    Going here :thumb:
    Thanks Canardwc :rock:
    Still has a lot of work to do to it... i want to add a lot more detail... lower diffuser and some detail around the blow hole with maybe some overlay.
    Ive made the GPU wider to accommodate the side adjusting GPU bracket.
    [​IMG] [​IMG]
    It's a large panel but light enuf to not add too much extra weight.
    [​IMG] [​IMG]
    Toru, Cheapskate, Canardwc and 2 others like this.
  4. Cheapskate
    13 May 2007
    There.. Fixed it. Don't get me started on fat USB sticks or power supply bricks without a lead.
    idpcmods and Defyant Mods like this.
  5. 4LIEN
    4LIEN Modder
    4 Jan 2020
    WOW! Your ability to work and shape plexiglas impress me every time!
  6. Defyant Mods
    14 Sep 2004
    LOL :hehe: :thumb:
    Cheers 4LIEN tyvm :rock:
    Very small update....You had to know this was coming :grin:
    [​IMG] [​IMG]
  7. idpcmods
    idpcmods Minimodder
    30 Jun 2015
    Dat ass :eeek::grin:
  8. Cheapskate
    13 May 2007
    Speedy plumber's crack. :D :thumb:
  9. 4LIEN
    4LIEN Modder
    4 Jan 2020
    Look like a racing car rear diffuser! :grin: I love it! :clap:
    Dot_Kappa, Defyant Mods and Canardwc like this.
  10. Defyant Mods
    14 Sep 2004
    Thanks mate :D I do like a nice rear end! :naughty:
    LOL the image that conjures up.... A good place to park the pushy!
    Thanks mate :rock: gotta live up to the Hyper Branding :D
    Small update today that actually took a bit of work!
    [​IMG] [​IMG] [​IMG]
    Dot_Kappa, Canardwc, 4LIEN and 5 others like this.
  11. 4LIEN
    4LIEN Modder
    4 Jan 2020
    Whatttt! :jawdrop: Incredible!
  12. Canardwc
    22 Sep 2011
    Quite impressive !
  13. MADPC
    MADPC Minimodder
    10 May 2020
    all very nice but will it be robust enough? what kind of glue did you use?
  14. censored_Prometheus_
    censored_Prometheus_ Minimodder
    26 Mar 2019
    Would be surprised if not cyanoacrylate. :eyebrow::cooldude:
  15. Defyant Mods
    14 Sep 2004
    TYVM 4LIEN :rock:
    Cheers Canarwc tymate :rock:
    Weldon3 for anything that's flush, Weldon16 for everything else . Pretty the same stuff ive been using since my first plex case mods almost 20 years ago :D
    When you find a good glue you stick to it !!!!!! :lol:
    It's surprisingly rigid.. Very little side to side flex... and once the 4.5mm side panels are added it will be as good as any chassis case.
    Cheers cP i think it says that on the side of the can :)
  16. idpcmods
    idpcmods Minimodder
    30 Jun 2015
    Or it sticks to you :winking::winking:
  17. Defyant Mods
    14 Sep 2004
    Small update again soz guys, Well.... alot of work for small results :D
    Almost done with this panel.. Fill a few ruff spots with spot putty a rub and final primer.
    First off was to get some primer down.
    [​IMG] [​IMG]
    [​IMG] [​IMG]
    Not sure what to call these things, but hopefully they look cool! i'll show the inspiration for adding these soon.
    [​IMG] [​IMG]
    A lot more sanding some more primer and a few coats of spray putty.
    [​IMG] [​IMG]
    [​IMG] [​IMG]
    [​IMG] [​IMG]
    The inspiration :D
    DEEPCOOL'S ASSASSIN III COOLER FANS
    [​IMG] [​IMG]
    pccustom, 4LIEN, Jean R built and 3 others like this.
  18. idpcmods
    idpcmods Minimodder
    30 Jun 2015
    Is the little things... That's what makes this whole thing pop I always love your attention to detail especially given the construction method used :hip:
  19. kim
    kim hardware addict
    10 Jan 2016
    fact is, you really went the extra mile on this case :wallbash:, really stunning to see the way you form shapes out of acrylic :jawdrop:
    Dot_Kappa and Defyant Mods like this.
  20. Cheapskate
    13 May 2007
    Show them how it's done. :rock:
    It's getting wilder all the time. The last case pic looks like the post office smashed your case...in a good way.
