Scratch Build – Complete Hyper Case DM-01
Discussion in 'Project Logs' started by Defyant Mods, 14 Mar 2020.
  1. 4LIEN
    4LIEN Modder
    4 Jan 2020
    I really really love your details, but pictures are too small for me! :waah::lol:
    Defyant Mods likes this.
  2. DSTM (Dougie)
    DSTM (Dougie) What's a Dremel?
    27 May 2020
    Amazing Mod. Looking great,mate.:rock:
  3. Defyant Mods
    Defyant Mods Multimodder
    14 Sep 2004
    Cheers idpc tyvm mate :) I'm using the most versatile best tools in the world! my hands :grin: lets see a 3D printer make you a cuppa @ the end of a hard days modding :p
    As always thanks kim your support and others keeps me modding :rock:
    Cheers Cheaps :thumb: Us old skoolers gotta keep the flag flyin! LOL thank god they dropped it on the front :p
    Cheers 4LIEn tyvm mate:rock: I thought keeping them smaller would be better to help the pages load faster... i just move on every time i see some one here post stupid big pics....
    I'd be happy to upsize , Say to 800 x 400?
    Cheers Dougie :rock: It's great to have your support over here too mate :thumb: Hope you are well buddy. We need to catch up soon.
  4. Defyant Mods
    14 Sep 2004
    Small update :) With Updates! Up-sizing the pics lemme know if you guys prefer the bigger size. :thumb:
    Appols for the lack of posts .. I have been modding.... just nothing major.
    All sorta just finishing off bits and redoing others.
    @Jeff Hine said:
    Purely out of curiosity, I can't tell if this is a 'stone' effect or whether it's been sprayed with a dusting of paint to detect high spots to be sanded off, at a later date... either way, it's a level of attention to detail that is highly creditable.
    The idea for the Black shadow is to use the black as a guide for sanding. Using a flat black you sand and whats left in black is "low" you can decide if you want to keep sanding or use a high filler and go again.
    [​IMG] [​IMG] [​IMG] [​IMG]
    As you can see above i decided to "keep going" then primer and spray putty and use some putty to fill the small low up top.
    Pretty much the same for the new back panel. Sand and fill some small lows and blemishes as well as adding a very ruff cut for the power....
    One of the "re do" things was the rear diffuser.... i decided to make it a stand alone section.
    Another "Re do" was the top section,
    ETD's!
    Exhaust Turbulence Reducers !!! Thanks to and ocau member :)
    [​IMG] [​IMG]
    And finally Some mesh is added to the front Vents
    More to come tomorrow :D
  5. Dot_Kappa
    Dot_Kappa 100% Puppet
    23 Mar 2006
    I agree with you Kim :thumb:
    Few modders are able to shapes plexi in this way :clap:
    DSTM (Dougie), kim and Defyant Mods like this.
  6. 4LIEN
    4LIEN Modder
    4 Jan 2020
    I really love all the detail, also the top section! The "re do" process it's really frustating, i know very well!
    For the picture size.... bigger is always better! :grin: Now i can see better your beautiful plexi work!
    Also, I think that in this forum all user have a 22" or bigger screen! (i hope :hehe:)
  7. Defyant Mods
    14 Sep 2004
    Cheers DK thanks mate :rock:
    Redo, remake, take 1 take 2 take 3..... if you guys could see the pile of stuff that hasn't made into this case...... i might do a show @ the very end just for giggles....Defyant's Gag reel !
    Cheers 4LIEN ty mate :D
    4LIEN likes this.
  8. Defyant Mods
    14 Sep 2004
    Another one of those "side tracked" moments :D
    Decided to add a PSU cover.... this will help to hide some of the spaghetti and another lil mod i have in mind :D
    I'll skip thru the usual cut and glue stuff... and jump to this.
    [​IMG] [​IMG]
    Then i made one of these
    To make one of these
    A splash of paint and guide coat a lil bit of temp tape starts to take shape.
    [​IMG] [​IMG]
    A simple slide fit
    [​IMG] [​IMG]
    Snug fit and yes it has a hood scoop :)
    [​IMG] [​IMG]
  9. Cheapskate
    13 May 2007
    Best pasketty pot ever!
    A mobo cover is calling...
    Defyant Mods and idpcmods like this.
  10. censored_Prometheus_
    censored_Prometheus_ Minimodder
    26 Mar 2019
    PERFECTLY! :dremel::thumb::thumb::thumb:
  11. Defyant Mods
    14 Sep 2004
    I remember doing my first mobo cover back in 2003 .... i'm sure they called me a nutter back then......
    :thumb:
  12. Defyant Mods
    14 Sep 2004
    Another one of those side track moments.....
    Starts off with one of these :) It gets stuck here and used to cut a nice big hole :)
    [​IMG] [​IMG]
    From the front side the edge is bevelled. Front fan duct is added to check clearance
    [​IMG] [​IMG]
    Then the GPU is sat in place to check clearance and the Stats screen is placed.
    [​IMG] [​IMG]
    The screen is a repurposed Samsung Galaxy SII Running an Android app that connects to the PC via WiFi. The interface is fully configurable. Power is added Via a usb to header cable and phone is set to always on while powered.
    The top bar can be removed via a setting (always full screen). The stats you are seeing is from my PC in the house... thanks to WiFi.
    [​IMG] [​IMG]
    A secondary screen for more info can be run @ the same time...
    pccustom, ivory2k19, 4LIEN and 3 others like this.
  13. Dot_Kappa
    23 Mar 2006
    I realized the case's size only with the gpu in place ..... I thought it was smaller :worried:
    Great Idea to recicle an old smartphone :idea:
    ivory2k19 and Defyant Mods like this.
  14. 4LIEN
    4LIEN Modder
    4 Jan 2020
    Very good idea with that old galaxy, what app do you use?
  15. Defyant Mods
    14 Sep 2004
    Cheers DK :rock: It is a beast!
    Cheers 4LIEN :rock:
    Remote System Monitor, Really cool App ! With tons of potential :thumb:
    4LIEN likes this.
  16. pccustom
    pccustom Multimodder
    12 Jul 2017
    I LOVE IT AGAIN!!
  17. Defyant Mods
    14 Sep 2004
    We're on the home stretch now ! ..... well until i change my mind again :p
    Yesterday was all the boring stuff..... more sanding and spot putty work... but today was a bit more fun as i finally get to throw down some colour :D
    First the boring! Kinda like running around putting out all the little spot fires.
    Some final prep work to the PSU cover, Filling in all the plex joins and fixing a few small dimples.
    [​IMG] [​IMG]
    It's a lotta extra work, but the end result will be worth it.
    Not sure if any one noticed this before but i changed the front. Decided to carry the lines thru to the bottom of the panel for a cleaner sharper look.
    This added a couple of extra days work... but i think it's worth the time.
    [​IMG] [​IMG]
    Then finish off the bracket for the Galaxy II Stats screen :) It's a simple spring type clip mod, that just holds the phone snug in place.
    [​IMG] [​IMG]
    A hell of a lot more wet rubbing and more spot fires and all the parts under base coat (silver)
    A day later....just when you thought all the wet rubbing was over ..... It's more wet rubbing again....
    [​IMG] [​IMG]
    Why sand every coat? To get the paint as flat as poss.... that is what gives the mirror finish @ the very end.
    [​IMG] [​IMG]
    Fun Time :D First a few coats of the gun metal and then on goes the 2K clear coat.
    [​IMG] [​IMG]
    Lets do a few more :)
    [​IMG] [​IMG]
    [​IMG] [​IMG]
    Just for giggles! what could have been!!!!!
    [​IMG] [​IMG]
    Taritha, 4LIEN, ivory2k19 and 6 others like this.
  18. Cheapskate
    13 May 2007
    Holy sh- When did that happen? :lol:
  19. censored_Prometheus_
    26 Mar 2019
  20. DSTM (Dougie)
    27 May 2020
    WOW.:thumb:. This build rocks.
