Scratch Build – Complete Hyper Case DM-01
Discussion in 'Project Logs' started by Defyant Mods, 14 Mar 2020.
  1. kim
    kim hardware addict
    10 Jan 2016
    That has a whole other meaning now with the metallic paint :jawdrop:, I absolutely love it :rock:
    Defyant Mods likes this.
  2. pccustom
    pccustom Multimodder
    12 Jul 2017
    great work why did you paint blue before? is it a primer?
  3. Defyant Mods
    Defyant Mods Multimodder
    14 Sep 2004
    Cheers Cheaps :rock: Just a lil something i knocked up in the add break :grin:
    Thanks CP :rock:
    Heya Buddy :) thanks mate:thumb:
    Thanks Kim :rock: I love the colour the more i put down the more i wanna see the whole case this way :)
    Cheers pcc :rock: The Blue is a "high fill" The primer was grey, the base primer for the primer was clear.. Paint wont stay stuck to plex.... even if the plex is sanded. It will still look bad.
    So some plastic primer is put down to help the primer stick. Then you can use the High Fill primer (Blue paint) You then sand that flat and apply more grey where and if needed then sand again if needed.
    Then put your paint down and sand again. Then clear coat (because this is metallic ) then sand again and then buff.:rock:
    It's a really long process if you want to do it right. But as i think you will agree the end result is miles above just spraying paint over sanded plex.:thumb:
    ivory2k19 and pccustom like this.
  4. Defyant Mods
    14 Sep 2004
    Today's effort was more sand paint ..... 3 days of sucking down paint fumes.... reminds me of my old amyl nitrate snorting days! :lol: :nono:
    After laying down some colour and some clear then letting it dry over night. The psu cover gets a quick light sand. This is to get the clear as flat as poss for a quick buff.
    Normally i'd let this sit for a week to let the clear go rock hard. But i wanted to see what sort of mirror finish i could get now.
    Looking promising,
    If i can get the whole case to look this good i'll be a happy camper.
    Happy with that i can get the last 3 sections under colour.
    A bit more prep work for the front panel and then some colour and clear cloat.
    [​IMG] [​IMG]
    Thought i'd take a sneaky peek @ how the black side vents would contrast!
    Then move onto some big stuff ! :p remember these ?
    That's pretty much all the players on the park now... I still need to wet sand and clear coat the top and back panels... prolly thru the week.
    Then i can finally start thinking about adding some hardware.
    [​IMG] [​IMG]
    Taritha, 4LIEN, Jean R built and 7 others like this.
  5. MaximumBubbleMods
    MaximumBubbleMods Minimodder
    22 Apr 2020
    Can I also compliment you on your photo taking skills as well! Looking so great :rock:
  6. Cheapskate
    13 May 2007
    :eeek: I like how you dropped that little tidbit like it's nothing. :lol: I just had a flashback to "blowchuckin/bedwettin" Bob.
    -The case is gonna be delicious.
  7. ivory2k19
    ivory2k19 Minimodder
    8 Feb 2019
    Wow :jawdrop:
    This is a lot of work my next steps are the same spot putty, wet sanding and repeat 1000 times :duh:
  8. 4LIEN
    4LIEN Modder
    4 Jan 2020
    OMG, that colors are porn combo! :grin:
    The clear silver paint look like real aluminium! :eeek:
  9. idpcmods
    idpcmods Minimodder
    30 Jun 2015
    Ill be fair that silver made a very striking contrast :naughty:
  10. Defyant Mods
    14 Sep 2004
    Cheers MBM :rock: I really do struggle with pics... you really have to work to get the best out of a mobile phone :)
    LOL Slip em in see who reacts :p Cheers mate tyvm :rock:
    Oh man , it really does feel like a lotta work , But the end result says it all when you get great comments like these :rock: Cheers m8 tyvm :thumb:
    INR!!!it was sooooo tempting to not go with the original plan....but ive had this one dream for this case for soo long now...
    But you have got me thinking :idea: Cheers mate tyvm :rock:
    I hear ya mate :D 4LIEN and yourself have me thinking :grin:
    ivory2k19, idpcmods and 4LIEN like this.
  11. Defyant Mods
    14 Sep 2004
    The next few posts will be a lot more of this stuff, but this is like the payday after months of slogging it out in the workshop for me :D
    So please indulge me will i keep updating with buffing pics :D
    Shots like these just feel so silly to take.....
    Dat shine!
  12. Cheapskate
    13 May 2007
    "looks factory" is a phrase that can't be used here. Nothing that looks that good comes from a manufacturer.
  13. riekmaharg2
    riekmaharg2 has completed the PowerCore scratch build
    22 Feb 2009
    Loving the attention to detail on this build, I actually thought those grey scale pics on the first page were milled aluminium panels, you certainly obtained a flawless finish. Makes me wonder for my future uses, if you could get a matt finish if it would look like gun metal anodised aluminium, although it does look really nice in that silky smooth gloss :thumb:
  14. Defyant Mods
    14 Sep 2004
    Cheers Cheaps :thumb: Now i know how Star Lord felt when they finally said his name right :D After 20 years and 20+ case mod builds that has been the goal :rock:
    Cheers riekmaharg2 if only i could work metal like that :thumb: But again that was the plan :D . I did debate for a while weather to go with MATT Clear or Gloss. Woulda been a lot easier that's for sure cause buffing a shine onto a layered non flat surface has proved to be a real challenge.
    I have been busy! more buffing making small adjustments and fitting up.... i have 3 different side panels in the mix atm. Full tinted sides a normal type panel with window inserts and mini slim clears for the open look.
    Sneaky preview with the open style front panels :p it's been cold out in the work shop !
  15. idpcmods
    idpcmods Minimodder
    30 Jun 2015
    *insert homer drooling gif here*
  16. DB Custom Towers
    DB Custom Towers Just a woman interested in art and PCs
    30 May 2020
    Loving it! Can't wait to see the final result
  17. Yargen
    Yargen What's a Dremel?
    1 Aug 2020
    Great Work :thumb::thumb::thumb: I feel like I just have to ask: Do you cut the Plexi all by hand? It´s hard for me to imagine this craftmanship but I´m only getting started since three years...So I see I have a lot to learn left ;):dremel: Definately trying to use your way to finish the acrylic next time though :)
  18. Defyant Mods
    14 Sep 2004
    Cheers idpm tyvm mate :rock:
    Cheers DB tyvm, Same here buddy i cant wait too! sorta dragging on.
    I dont have a any automated machinery.... tho some times i think after maybe 30 case mods i should.....
    I do all my work by router to edge. Even a simple straight line i do with the router. Im too impatient and not skilled enuf to ever try and cut a line with a saw buy hand.
    Some of my older worklogs show the method, i tend to leave it out now as i thought most are sick of seeing it :D
  19. Defyant Mods
    14 Sep 2004
    Not much of an update soz ... but one ive taken way to long to think about.
    The mesh for the top vents is shaped and glued into place :)
  20. pccustom
    12 Jul 2017
    GREAT!!!
