Scratch Build – Complete Hyper Case DM-01
Discussion in 'Project Logs' started by Defyant Mods, 14 Mar 2020.
  1. 4LIEN
    4LIEN Modder
    4 Jan 2020
    The final shape is definitely the right shape for this case!
    But i have a doubt now, with the tinted panel, you lose the effect of illuminated borders
    Defyant Mods likes this.
  2. DB Custom Towers
    DB Custom Towers Just a woman interested in art and PCs
    30 May 2020
    All of them look good. Tinted is definitely the way to go with that color scheme. Looking sleek!!! Great job!
  3. Defyant Mods
    Defyant Mods Multimodder
    14 Sep 2004
    Cheers Cheaps
    The loft of the garage is about to collapse under the weight i have soo much of this stuff horded :(
    I like the machined edge look ! i might leave it on the tinted clear to catch the light but buff the clear :thumb:
    Cheers kim that's a real compliment tyvm mate :rock:
    The beauty is i have both sets :) one for inside (tinted) and the other set clear for glow and show :D :thumb: And.... working on a 3rd set of panels :naughty:
    Cheers DB much appreciated :) :thumb: Hopefully the next set will be as impressive.
  4. Defyant Mods
    14 Sep 2004
    Its a small update, but one ive sat on for a week now deciding.
    As you can see here i had a small dilemma .............
    Still need to source some small hex head type screws and tap some threads.
  5. Cheapskate
    13 May 2007
    By 'dilemma' I assume you mean the upside-down logos? I thought they were supposed to be upside down? They always seem to end up that way.
  6. konkers
    konkers What's a Dremel?
    16 Mar 2015
    Seeing what's possible out of sheets of acrylic is truly inspiring!
  7. riekmaharg2
    riekmaharg2 has completed the PowerCore scratch build
    22 Feb 2009
    Suppose you could always mod the SSD's so your not looking at upside down logos :D
  8. Dot_Kappa
    Dot_Kappa 100% Puppet
    23 Mar 2006
    Uhm...what about a sticker ? :naughty:
    That kind of sleeving remind me Matrix :grin:
  9. Defyant Mods
    14 Sep 2004
    Still deciding if i'll stay with the matrix style sleeving or just give up and go with cable mods cables...
    I did have a good look @ opening and turning the lids around on the SSD's . The mounting screws are a one way pattern as well as the cut away for the connection area.
    I did think long and hard about stickers too :thumb: i have some spare carbon vinyl too ! But decided to go with the removable covers :grin:
    I think the coat of paint will will make all the difference. I did play around with adding a pattern but decided leaving them clean was a better look.
    Some small SS hex heads finishes them off.
    I'm holding off tapping into the side panel just for now and will used some D'sided tape till i'm 100% sure i want to commit.
  10. 4LIEN
    4LIEN Modder
    4 Jan 2020
    I really like the sleeving with electrician tube!
  11. Defyant Mods
    14 Sep 2004
    Cheers 4LIEN :thumb: i didn't want to just give in and go with cable mods.....i may still "give in" cause it's easy... but i'm kinda sick of seeing the same thing over and over.
    Time to add the power extender cable and fill that annoying hole
    Ive decided to go with the extra fan on the cpu cooler to make a triple cooler with fourth fan for exhaust.... A quick look using some spare Cryorig fans while i wait for my second Assassin III to arri
    Compared to a Dual setup Hyper 212x this thing in triple fan mode is massive!!
    With the triple fan setup it will really fill out the space.
    Next in with the GPU and lower cover .Still on the hunt for a larger unit with all the 3080 cap drama's i'll hold off a bit longer.
    A few Bum shots!
    Some Lip Service :)
    I thought i'd drag out old bertha for a quick size comparison.....
    When the lights go out the devil within shines !
    Still got a few updates :)
    Rear Mesh
    Cables
    Side Panels
    Finish front orig front grill
    Extra cpu /exhaust Fans
  12. Cheapskate
    13 May 2007
    Public library drive-by?
  13. DB Custom Towers
    30 May 2020
    Loving it!!!!
  14. Defyant Mods
    14 Sep 2004
    The Second Assassin III finally arrived :D And the quad fan wind tunnel could finally be finished.
    With due haste some holes are drilled and tapped into the rear panel
    It's a beastly cooling setup near 24cm long
    Still one small signature addition to add here :D
  15. Defyant Mods
    14 Sep 2004
    Still early days but it's good to be back on the horse.
  16. pccustom
    pccustom Multimodder
    12 Jul 2017
    SUPER WORK BRO!
  17. Cheapskate
    13 May 2007
    DUCKS! :thumb:
    This is getting very Japanese drift car. :D Just don't add decals of your digital wife.
  18. 4LIEN
    4LIEN Modder
    4 Jan 2020
    Very happy to see update here!
  19. douglas alves
    douglas alves Minimodder
    3 Mar 2014
    Very good.
    Congratulations.
  20. Defyant Mods
    14 Sep 2004
    It's a slow old horse sorry guys :)
    4LIEN, ivory2k19, Toru and 3 others like this.
