Modding I am in need of some blowhole templates
Discussion in 'Modding' started by Hamham, 21 Apr 2002.
  1. Hamham
    Hamham What's a Dremel?
    1 Feb 2002
    I need 80.92.120mm templates that are capable of being printed out.
    Thanks
  2. brianpodskalny
    brianpodskalny ladies night!
    3 Nov 2001
    a cd is 120mm
    for the rest, why not just measure yourself.
  3. Lazy
    Lazy Meow?
    13 Nov 2001
    i think there are some on here
  4. Lazy
    Lazy Meow?
    13 Nov 2001
    it is confirmed there are some there
  5. neuro
    neuro What's a Dremel?
    9 Jan 2002
    these ones are cool.
    http://neuro.woaf.net/fan/
    ...all credit goes to the people who made these templates, might have been moddin.net, c the template! :)
  6. tk421
    tk421 Idiot.
    15 Jan 2002
    who needs templates? just buy holesaws. trust me, it makes life MUCH easier, especially if you work with plexi ..
  7. Vectrex
    Vectrex What's a Dremel?
    21 Apr 2002
    Dood, you dont need a template! Just use a fan grill, whatever size fan your going to be using, and trace around that. Works Perfect!
    As for the holesaw comment... I went and bought one yesterday and I love it. It's kinda scary to use heh, but it works great, and you get that perfect circle you've always wanted :).
  8. Lazy
    Lazy Meow?
    13 Nov 2001
    as a template is free it is a lot cheaper than a hole saw.
  9. Vectrex
    21 Apr 2002
    Even when using a holesaw, you use some sort of template. You still have to drill holes where the screws need to go, and for that, you want to have to place marked before you drill your big giant hole. Se either way, you HAVE to use a template, but the hole will come out so much better with a holesaw.
  10. Hamham
    1 Feb 2002
    I need templates because I can be retarded sometimes and I think it is much quicker than tracing. By chance would u have any round templates? THe one u provided were kinda square.
    thanks :hehe:
  11. kanuslupus
    kanuslupus Minimodder
    10 Mar 2002
    Or you could just use the fan to mark the mounting holes after the "holesaw" hole is done. I suppose you could call that a template.
  12. Jamie
    Jamie ex-Bit-Tech code junkie
    12 Mar 2001
    We do actually have some BiT-Tech blowhole templates however we no longer have a downloads page so only people that used the old site will know.
    So here they are:
    120mm
    92mm
    80mm
  13. tk421
    tk421 Idiot.
    15 Jan 2002
    you dont HAVE to use a template ... just take the fan (gasp) and put it where you want it, put a dot in each screw hole, connect opposite screw-hole-dots with straight lines, and put the arbor of your holesaw in the middle of the big X it makes ...
    i guess i should read other replies before i get all smart arsed ...
