TVs I am looking for 40 inch 4k TV suggestions for console gaming
Discussion in 'Hardware' started by kuroidoragon, 16 Jan 2021.
  1. kuroidoragon
    kuroidoragon Minimodder
    14 Oct 2012
    Can someone suggest me a not to expensive but decent
    40 inch 4kTV
    50/60 HZ refresh rate
    HDR
    with a stand that is more central to the under neath of the tv - not one of those ones where the feet are at either far end of the tv ( it is due to where I shall place the tv)
    at least 2 HDMI slots
    it is to use with my PS5 (I am happy with 4k)
  2. sandys
    sandys Multimodder
    26 Mar 2006
  3. kuroidoragon
    14 Oct 2012
    thanks for the response but all those tv's are over 40 inches not what I asked for anyone able to suggest me some tv's ?
    there maybe only one out of that list a 43 inch one with not the right kind of tv stand not sure I have the room for that
    https://ibb.co/yf7j5MW
    I am trying to avoid what I am doing in this picture (GHETTO SETUP)
    I could go a little over 40 inches but for reasons shown in the image the stand is prefered to be more central along the bottom of the tv
  4. sandys
    sandys Multimodder
    26 Mar 2006
    I can see you issue but the thing with these screens is that they often come in smaller sizes so still worth a look
    The_Crapman and kuroidoragon like this.
  5. wolfticket
    19 Apr 2008
    A stand like this: https://www.amazon.co.uk/1home-Univ...-Management-Holds-32-55-Height/dp/B075FN4GH5/
    ...Can allow any TV with VESA mounts (which should be most(?)) to have a central stand. I had the same issue with an similar style of LG TV and a TV bench not quite wide enough. Even if you still want to upgrade the TV it means you don't have to rely on getting one with a suitable stand out of the box.
    kuroidoragon likes this.
  6. kuroidoragon
    14 Oct 2012
    Still need to find some 40 inch 4ktv though still got a bit off topic with my ghetto setup there
  7. sandys
    sandys Multimodder
    26 Mar 2006
    It seems to be an unpopular size these days, so looks like you'll be limiting yourself, perhaps a monitor would do better as the step down from 43 seems to be 32 in most TVs and the 32s don't appear anywhere near as good, does it need to be a TV?
    but yeah a wall mount or central stand could help you out with bigger,or bigger desk/chest of drawers, there is no getting away from the size of playstation and these these are often best on big screen sat back.
  8. kuroidoragon
    14 Oct 2012
    SO ANYONE ABLE TO SUGGEST some 40 inch 4k tvs for console gaming ? no ones really answered yet
  9. sandys
    sandys Multimodder
    26 Mar 2006
    As mention for your requirements you are out of luck, once you click 4k on TVs there is basically nothing with a central stand at 40", so you won't get many answers.
    simple filtered link on 39-46" tvs, you have buggerall to choose, so if you can't be flexible with requirements just pick something that fits your requirements here, there is only a handful that might fit, can't magic up something that doesn't exist.
    4K HDR TVs - Cheap 4K HDR TVs Deals | Currys
    Personally with PS5 I would be holding out for a HDMI 2.1 screen for higher refresh plus VRR goodness but they won't come in 40" and likely won't come with a stand you want, LG are releasing the C1 OLED in 42" that would probably fit having really small bezels and the LG OLED stands are generaly central, they have all the features 4k120hz, gsync/freesync, HDMI2.1 etc, not out yet but wouldn't expect much change from £1500 if the LG CX48 is anything to go by, OLEDs are not perfect though, not bright enough for HDR wow factor in gamesbut still very good, superb for media.
    All the TVs that fit similar spec with PS5 features that are cheaper are into the 49-55" range.
    With respect to HDMI 2.1, all the TVs announced so far on this database hardly anything at 43, nothing below
    List: 4K TVs and 8K TVs with HDMI 2.1 - FlatpanelsHD
    you could get a short throw projector? again not cheap
    The_Crapman, kuroidoragon and adidan like this.
  10. Bloody_Pete
    Bloody_Pete Technophile
    11 Aug 2008
    LG are also releasing the more budget A series OLEDs soon, so they'll probably be in this size and cheaper, but not much is known spec wise.
    Edit: Flicking through Box there are 2 43" TV's with central stands, so thats basically your lot.
    https://www.box.co.uk/tvs/refine/48047~33_43
  11. adam_bagpuss
    24 Apr 2009
    just a thought - how close are you sitting from your 40" TV ?
    4K content on a screen that small (which is why they dont really have many options) doesnt really benefit from the imprioved visuals on the whole.
    https://www.rgb.com/display-size-resolution-and-ideal-viewing-distance
    To get full benefit of 4K you need to be sat @ 2 1/2 ft or less which is around less than 1m and to see improbement your talk 5ft or less than 1.75m
    this is why in general it makes no sense to have high resolution on really small screens.
    Im not saying this is the definitive as peoples eyes are different and its subjective but this gives you the overall jist
  12. kuroidoragon
    14 Oct 2012
    at a guess & I am not a genius i would say at most 1 & half meter
    I did notice the difference changing from a HD to a 4k telly even at that rough distance I have allways had a tv in the same place
    any suggestion for 40 inch 4k tv's or (Slightly) higher are welcome still not had any suggestions
  13. adam_bagpuss
    24 Apr 2009
    quik scan shows this one, almost all of them are 43". no idea how good it is but its the only one i can find
    Panasonic TX40HX800B
  14. The_Crapman
    5 Dec 2011
    Come on mate, you've been given A LOT of suggestions and advice. You're just not listening and have shown no interest in doing any leg work yourself. Take the information and suggestions you've already been given and do some research yourself.
    modd1uk, sandys, Bloody_Pete and 2 others like this.
  15. kuroidoragon
    14 Oct 2012
    just because I don't show it here how do you know I have not looked myself did you think of that how do you know I haven't looked before posting here ?
    & most posts except a couple have not helped a great deal with my original question. I have liked each post to show my appreciation for trying
    so both counts of you saying I have done no leg work is false & peopole making (plenty) of suggestions to do with my original question is false
  16. The_Crapman
    5 Dec 2011
    You mean like:
    • how you have offered no suggestions of models and whether people think they'd be good.
    • You've been linked an article on the best monitors for 4k console gaming but couldn't extrapolate that to a smaller version of the same model, even when it was pointed out.
    • You've ignored 2 people's advice of widening your search to include TV's with any type of footing because you can get a separate centre footed vesa mount.
    • You've been linked 2 different websites filtered to what could meet your needs.
    • Advice and a further link for hdmi 2.1 TVs
    • Advice on viewing distances and whether 4k might definitely be worth it.
    • When you were linked an exact model for your odd and very specific requirements you couldn't even be bothered to Google it's refresh rate.
    Sentinel-R1 and adidan like this.
  17. Big Elf
    23 Apr 2009
    I'm planning on getting the Panasonic TX40HX800B mentioned above when it's back in stock at Panasonic. They told me it's due in early February. You can get one from a reseller with poor rep on Amazon at a rip off price (£70 extra) or contact RicherSounds by phone (no other option), I gave up after being cut off twice.
    I also wanted one with a central stand. The specs seem decent for the price rather than outstanding.
    Review
    I would have normally bought a Samsung but my current one has been rubbish for longevity. Bought in 2015, a big purple blotch (common fault) appeared in 2018 and now there's 4 grey areas on screen presumably where the back-lighting has failed.It's going to be funny watching a TV again without the purpleness.
    adidan likes this.
  18. Big Elf
    23 Apr 2009
    Panasonic TV is now available on Amazon from a seller with good rep for £549
  19. Big Elf
    23 Apr 2009
    My Panasonic TX40HX800B has been delivered 2 days early. Very impressive but there again compared to my blotchy Samsung I suppose anything would be. Relatively easy to setup, very nice picture and an unexpected bonus is the built in Bluetooth which has no lag/lip sync problems.
  20. ModSquid
    ModSquid Multimodder
    16 Apr 2011
