Modding I cannot find yellow led fans anywhere on this planet...
Discussion in 'Modding' started by retrogamer, 13 Mar 2005.
  1. retrogamer
    retrogamer What's a Dremel?
    23 Aug 2004
    ...let alone 120mm yellow led fans!
    what size leds are in 120mm fans, i might just buy some yellow leds and with a bit of :dremel: modding i could probably swap them around with another colour :)
  2. rob_65
    rob_65 What's a Dremel?
    5 Apr 2004
    5mm LEDs would be used in those fans.
  3. Leeum
    Leeum What's a Dremel?
    16 Feb 2004
    I'm sure Cooler Master do gold LED ones, don't hold me to it ;)
  4. FRiGUi62
    FRiGUi62 What's a Dremel?
    13 Aug 2004
  5. Brew
    Brew What's a Dremel?
    8 Apr 2004
    Well...just a thought but you could just get yellow LEDs and you know, mod an existing 120mm LED fan.
  6. foxx
    foxx What's a Dremel?
    5 Sep 2004
    Brew: You know what pisses me off...people who read the first sentence in a post than think there smart post an answer then I have to tell them to read the whole post so they can give the correct answer.
  7. mattthegamer463
    26 Nov 2004
    ya, it would take you like 10 minutes tops to unsolder the old ones and solder in new ones.
  8. GlassX
    GlassX What's a Dremel?
    11 Jul 2004
    I dont think superbright yellow led's exist... amber, orange and weak yellow, never seen a superbright yellow though.
  9. Firehed
    15 Feb 2004
    I've never even seen a dim yellow. Close, but never quite right.
  10. douphus
    douphus What's a Dremel?
    26 Aug 2004
    Where would you get yellow LED's? Radio Shack?
  11. rebox
    rebox What's a Dremel?
    31 Jan 2005
    I can recommend 123leds.com, took less than a week for me to get it shipped here and dirtcheap :)
    hopefully every led is working, havent tried them all :hehe:
  12. Nexxo
    23 Oct 2001
    It would take even less time than that to read the post properly. ;)
    Visit http://www.ultraleds.co.uk for all your LED needs. :thumb:
