Case Mod - Complete "I choose you" by RandomDesign
Discussion in 'Project Logs' started by random2k4, 3 Jun 2019.
  1. random2k4
    random2k4 Multimodder
    11 Aug 2015
    Time for a new project.
    This time only something simple, cause I had to finish the mod in only 8 days to
    ship it to Taiwan for computex.
    As you can may tell from the title, the theme is Pokemon :D
    The base will be the Level20 from Thermaltake.
    So first a pic of the used parts.
    The Level20 is one hell of a case, 32kg of pure case (empty)
    First I removed all the uneccesary parts. So basically everything.
    I will start with the top compartment. Later each section will have its different theme.
    My plan for this part is, to include 3 water tanks an ad a little detail in the tanks.
    Cause water tanks alone look a bit boring, I 3d printed a small ring.
    This ring will also hold them in place later.
    As a base, I cut a piece of plywood
    and included the holes for the cylinders as well as the fittings.
    First test looks good already.
    Dot_Kappa, Cheapskate and neSSa like this.
  2. Cheapskate
    13 May 2007
    TT's wallet.
  3. MLyons
    MLyons 70% Dev, 30% Doge. DevDoge. Software Dev @ Corsair Lover of bit-tech Administrator Super Moderator Moderator
    3 Mar 2017
    PC modding and Pokemon
  4. random2k4
    11 Aug 2015
    Next, I built a back panel for the construction that hold the water tanks.
    To hide the wooden grain, I first primed everything with white Gesso.
    Then gray paint was rolled on the surface.
    I designed, cut and dabbed on a thin detail line in a darker tone.
    Inside the small cut outs, i fitted acrylic glas for a small LED effect.
    Over the acrylic glas, I glued a cover. I also attached the 3D printed ring that will hold the water tanks.
    Then I put the LEDs into place. I also installed the water tanks and added the fittings in the colors
    of the first starter pokemon of the game for the Game Boy.
    Next up, I will use this little fellows here.
    Dot_Kappa and Lambda like this.
  5. Cheapskate
    13 May 2007
    Looks like you plan on some really tight tube bends there.
    I have no clue what pokemon is supposed to look like, so I'm trusting your judgement. :D I'm just here for the mod.
  6. Sa mod pc design
    Sa mod pc design Minimodder
    7 May 2019
    I love pokemoms and your work is extraordinary
  7. random2k4
    11 Aug 2015
    Thanks guys :D
    After I 3D printed small bases, it was time to finally place the Pokemon in the water tanks.
    Then, I bend some acrylic pipes, cut them to length and attatched them to the fittings.
    The entire construction was then placed inside the top compartment.
    Because normally the PSU should be placed in this section, there was still some work to do.
    I removed the parts that should hold the PSU and build a new cover, including holes
    for the ventilation and power plug.
    Afterwards, I simply covered the new cover with some vinyl in carbon look.
    In addition I also had to do the same for the inside.
    Dot_Kappa, MLyons and Cheapskate like this.
  8. Cheapskate
    13 May 2007
    The PSU exhaust is too restricted.
    The funny angle must be messing with my eyes. I thought the back tubes were a lot closer. It looks great.
  9. random2k4
    11 Aug 2015
    pssssst, its just for show ;)
  10. Landux
    Landux What's a Dremel?
    21 Jun 2019
    I've seen the pictures of this build at Computex and was my favourite.
    One of the cleanest and coolest design in my opinion!
  11. random2k4
    11 Aug 2015
    Thanks man!
    Next, I worked on the right compartment bearing the water tanks and radiators.
    First, I cut a wooden pannel to mount the radis into place.
    And ofc a first test fit.
    To hide the wooden structure, I covered everything with black carbon foil.
    Then, I also included the water tanks and tried to see on which hight they should be mounted.
    Cheapskate likes this.
  12. m0o0oeh
    m0o0oeh Minimodder
    20 Dec 2006
    I must confess I do like the staggered effect - I daresay it wouldn't stay like that but so far I'm loving this build!
  13. random2k4
    11 Aug 2015
    Next up, I built the mounting for the water tanks.
    I simply glued everything on a plywood sheet what will perfectly fit into the right compartment.
    The water tanks will be placed in the holes and stabilized from the bottom.
    To make the construction look more like a city scene, I 3d printed panels
    with windows inside. There will be a light effect later on behind the windows.
    For my next step, I needed to completely dismantle the LEvel 20. Which is suprisingly easy.
    Just unscrew some screws and you are done.
    After everything was dismantled, I set the position of the drain ports.
    neSSa and MLyons like this.
  14. abbas-it
    abbas-it We came, we saw, we mod, you awe!
    1 Jun 2011
    did you move from the garage into the house, aah i see, your wife lives in the garage now, priorities, yeah . :)
    naughty boy
    MLyons likes this.
  15. random2k4
    11 Aug 2015
    Using the garage for all the "dusty" work.
    For dismantling and assembly I am using my second workshop room.
  16. Cheapskate
    13 May 2007
    I had one of those...It's starting to look like the garage. :worried:
  17. random2k4
    11 Aug 2015
    Finally, I started to cover the case with yellow and black foile, to stay in the Pikachu/Pokemon theme.
    And ofc all the holes for the ventilation needed to be cut out.
    The front panel also got a small Pikachu silouette.
    On the inside, I put a part of the movie poster.
    Ob the back side I attached a second silouette and the name giving letters.
    Last, I build the water cooling.
    Its a tripple loop system with independant loops for the GPU, CPU and memory.
    MLyons likes this.
  18. random2k4
    11 Aug 2015
    And some pictures of the final mod.
    I also made a short making-of video:
    MLyons likes this.
  19. m0o0oeh
    m0o0oeh Minimodder
    20 Dec 2006
    Absolutely stunning! Love the completed mod! Pokemon + PC modding = Happy BoyTM!
    MLyons likes this.
