Electronics I Don't Like My Voltages
Discussion in 'Modding' started by Confusitron, 19 Apr 2003.
  1. Confusitron
    Confusitron What's a Dremel?
    22 Dec 2002
    12V+: 12.40
    5V+: 4.83
    3.3V+: 2.62
    I especially don't like my 3.3V+ lines voltage... I should buy a different power supply, shoudn't I? This was monitored through Motherboard Monitor 5.
  2. whypick1
    whypick1 The über-Pick
    17 Oct 2002
    Double check with a multimeter. If the readings it gives are fairly close to what MBM says, get a new PSU NOW!
    If you don't have a multimeter, get one NOW! If you don't have the money for one, steal one NOW!
    The +12v and +5v lines look fine though, well within tolerance.
  3. acrimonious
    acrimonious Custom User Title:
    8 Nov 2002
    Yeah i'll second that, if your M/B is right then that +3.3 is nasty.
  4. Smilodon
    Smilodon The Antagonist
    25 Mar 2003
    what PSU is it? i have heard that Aopen ones have pretty low on some... have one Aopen.. it looks fine on MBM5 though...
  5. rich_bytes
    rich_bytes What's a Dremel?
    30 Aug 2002
    Is your pc stable? I would have thought that if the 3.3v line was really that low it would be causing problems.
  6. Sc0rian
    Sc0rian Here comes the farmer
    23 Feb 2003
    its not that bad....
    This is mine at the time i did a print screen[​IMG]
  7. Confusitron
    22 Dec 2002
    ...This one... I was tricked by an Ebay auction. It claimed the parts inside it were manufactured by Channel Well Technology... Thank goodness I can still RMA it, or I could just not use it and buy another one since it was only $35.00. I would like to get either this (CWT) PSU, this (CWT) PSU, or this (Topower) PSU.
  8. cpemma
    cpemma Ecky thump
    27 Nov 2001
    Antec are quality, put together by CWT
    [​IMG] :thumb:
  9. Confusitron
    22 Dec 2002
    I've been trying to spread the word of that. They are quality, that is why I could save $20.00 buying a CWT PSU.
  10. cpemma
    cpemma Ecky thump
    27 Nov 2001
    The fact that CWT make the Antec psu doesn't necessarily mean the quality is identical on every unit - depends on how tight Antec's purchasing spec is compared to CWT's normal manufacturing spec.
