I have a cooling system to effectively cool to around -100C+/-20c Whats next?
Discussion in 'Hardware' started by qzjake, 26 Apr 2004.
  1. qzjake
    qzjake What's a Dremel?
    26 Apr 2004
    I have an awesome cooling system, but don't know where to go from here. I am curious now that I have this system, what can I do with it? Any recommendations? I would like to have something far better than you can buy off of the shelf(OTS) but still have the stability of an OTS system. Any help is welcome.
  2. Highland3r
    Highland3r Minimodder
    25 Jul 2003
    Are you asking what components to buy m8?
    Welcome to the forums as well :D
  3. olv
    olv he's so bright
    23 Sep 2002
    What is this 'cooling system' you have? A DIY compressor jobby like a Prommie of Vapochill?
  4. Kameleon
    Kameleon is watching you...
    29 Apr 2003
    Ahahaha, you mean like a Compaq? :hehe: Trust me, anything you make properly yourself will be far better than what the monkeys put together...
  5. calnen
    calnen moo!!
    2 Oct 2003
    The big boys for overclocking at the moment are the mobile barton cpus - I've heard of several people getting them up in the realms of 2.7Ghz with vapour-change cooling. (PR =about 4000+)
  6. Highland3r
    25 Jul 2003
    BigZ's had his to 3.1ghz! Custom PC had one to 3....
  7. calnen
    calnen moo!!
    2 Oct 2003
    And here's me running a t-bred 2400 with a standard coolermaster fan, lol...
    *cries*
  8. Tim S
    Tim S OG
    8 Nov 2001
    other way around... ;)
  9. planki
    planki ...
    20 Dec 2003
    now now dont brag :p
  10. Highland3r
    25 Jul 2003
    Sorry m8, have changed! :D
  11. Tim S
    Tim S OG
    8 Nov 2001
    btw.... make sure you have lots of neoprene... I have condensation problems with the evap at -28'C (core -2'C) from time to time...
  12. qzjake
    26 Apr 2004
    Yes, and thank you I am happy to be here.
    Thank you for the warm welcome.
    I am receiving a custom cooling system capable of holding temperatures between -100C & +60C (+/- 20C). Basically a solution looking for a problem. I just want to build a computer to justify the cooling system by providing massive horsepower.
  13. qzjake
    26 Apr 2004
    How about this one? Would a 64bit CPU be better?
    How do these look? Does anyone have any knowledge about 64 bit processors? I am really trying to make something much faster than a person can buy OTS (justify the $$ to the wife).
    barton CPU
    What do you think I could get out of this?
    64bit CPU
    OR!, What do you think I could get out of this?
    or if the money holds out...
    Opterons
    could I get this to perform
    better than this?
  14. SlackeR
    SlackeR What's a Dremel?
    17 Mar 2004
    as for the barton.. it will prolly be locked.. this will kepp you down if your cooler is as massive as -100c..
    at that speed i would opt for AMD64.. Maybe Athlon FX-53.. But then you will be better off waiting a short while for the new chipsets to arrive. it is complex right now..
    As an alternative you could look at the Prescotts.. i think they would scale great with a cascade(?) like yours.. The P4EE is performing great.. but its a hefty tag it carries..
    if you are going to buy NOW and dont like problems go for at mobile barton or a P4 with that cooler.
    If you like fiddling around the A64's are the kings. but the problem will be the missing agp/pci locks..
  15. Marvt74
    Marvt74 What's a Dremel?
    29 Mar 2004
    Some of the newer a64 boards available have working pci/agp locks
    I cant see you getting near 3ghz to be honest mate, not being harsh but the people that have have years of experience tweaking and modding computers to run at the top of thier ability. Someone new to overclocking/building computers as you sound to be may get 2.5ish or possibly more i'd guess
  16. olv
    olv he's so bright
    23 Sep 2002
    only if u get one with the via chipsets, nforce 150 chipsets have locks on iirc.
  17. Kameleon
    29 Apr 2003
    I can't see anything other than the nForce3 250 being king of the AMD chipsets in the near future...
  18. Marvt74
    29 Mar 2004
    I think theres a new via cipset coming out soon to have agp/pci locks and reports show it performing VERY well, i'll try and find a few links
  19. Tim S
    Tim S OG
    8 Nov 2001
    what about the VIA K8T800 Pro? it's sposed to be faster than the NF3 250Gb chipset ;)
    and it has working PCI locks afaik
  20. Guest-2867
    Guest-2867 Guest
    What is this insanely chilly cooling system you speak of?
    We want pics or a linky ! :dremel:
