Networks I have a Dynamic IP, Need Static - Options?
Discussion in 'Hardware' started by stu_69, 28 Aug 2007.
  1. stu_69
    stu_69 What's a Dremel?
    11 Mar 2004
    I have just had Sky BB setup and one thing I didn't think of when deciding on ISP's was a static IP address. I used to have one with BE but there is no option with Sky.
    I work from home a bit and I use a VPN to do remote Admin on servers which requires an IP address for the VPN. Obviously I can't do this now as it would require a firewall change on the work firewall every time I change IP address.
    So are there any options available to me?
    I would prefer not to have to install a client (ie no-ip) if at all possible.
    Stu
  2. Glider
    Glider /dev/null
    2 Aug 2005
    Call your ISP, for a fee they usually can set a static IP.
  3. WILD9
    WILD9 Been here aaaaages
    13 Sep 2001
    Some routers have the ability to communicate with a site like no-ip on your behalf so no nasty client to install.
  4. cpemma
    cpemma Ecky thump
    27 Nov 2001
    http://www.dyndns.com/services/dns/dyndns/
  5. Duste
    Duste Sierra my delta, bravo!
    1 Oct 2006
  6. stu_69
    11 Mar 2004
  7. BioSniper
    BioSniper Minimodder
    5 Feb 2002
    I was about to say the Sky router has a built in client for dyndns (you just have to set it up in the routers web interface) but alas it doesn't sound like that'd be much use to you :(
  8. steveo_mcg
    steveo_mcg What's a Dremel?
    26 May 2005
    Whats the ip for, in most cases you can enter the DNS and let the internet work it out for you.
  9. cpemma
    cpemma Ecky thump
    27 Nov 2001
    The word is, Sky don't do static, so you may need to change ISP to somebody who will.
    Check out how the dyndns thing works, written by another Sky user.
  10. crazybob
    crazybob Voice of Reason
    21 Oct 2004
    The importance of this will also depend on just how much your IP changes. My ISP only does 'dynamic' addresses despite the fact that mine hasn't changed in two years.
  11. Supra55
    Supra55 What's a Dremel?
    10 Oct 2006
  12. Hamish
    Hamish What's a Dremel?
    25 Nov 2002
  13. Kipman725
    Kipman725 When did I get a custom title!?!
    1 Nov 2004
    before changing to static IP consider the benefits of dynamic. Higher anonimity, non perment bans and quite alot of random internet problems resolving with a modem reboot. I have used no-ip in the past as they have a linux client and they are quite reliable, if you need an ip you could always just look at the ip the domain name is pointing to :)
  14. severedhead
    severedhead What's a Dremel?
    19 Dec 2002
    Freedom 2 Surf give static IPs as standard.
  15. seebul
    seebul Minimodder
    9 Aug 2005
    Should work the same way really? Just put the url in instead of an ip. Dyndns does the same as no-ip basically but without the client:/. I can't think of any other way you could do it.
