Windows I have a problem
Discussion in 'Software' started by Vampz, 13 Dec 2003.
  1. Vampz
    Vampz What's a Dremel?
    13 Dec 2003
    I was downloading a 650 mb file and when it was at 99% it closed. Before when I had this file at 50% it closed but I was able to retrieve it and I dont know how I did it. If someone could help me with how I could retreive the download at that percent, I would be grateful.
  2. pranks7er
    pranks7er mange tout
    25 Dec 2002
    well you should have used a download manager that allowsu to retrive broken downloads, pause etc, especially when you are downloading such big files.
  3. x3r0
    x3r0 What's a Dremel?
    29 Oct 2003
    and next time i'd try and post in a more relevant thread.
    </gripe>
  4. Guest-16
    Guest-16 Guest
    with a relevent title in a relevent forum perhaps?
    Nm, we were all n00bies once. :rolleyes: :lol:
    if it didnt complete its not written to disk iirc
  5. acrimonious
    acrimonious Custom User Title:
    8 Nov 2002
    Its written to a temp folder, thats why after a really big download you see the little copy window pop up and shift it to where ever you told it to save to :thumb:
  6. Guest-16
    Guest-16 Guest
    but it deletes the temp file if it doesnt complete iirc
  7. tk421
    tk421 Idiot.
    15 Jan 2002
    ok ... here goes ..
    i d/l large files quite often .. and i DO NOT use one of those stupid DL managers. all you have to do is :
    1: make IE's cache at least twice the size of the biggest file you DL
    2: only DL one at a time
    3: defrag regularly (at least once a month, whether you use fat or ntfs
    4: dont do anything that taxes your connection or your hd activity till the dl is done.
    i have a tendancy to download very large zips (up to a gb each) 2 at a time. so i set my internet cache to ~4 gb ... that way if one breaks, i can usually resume it no problem, unless i have to reboot ... having lots of ram helps too .. at least 512, 1024 is better. and having the hard drive that the file is gonna write to be the only device, on its own controller, can help aviod errors too .
  8. cpemma
    cpemma Ecky thump
    27 Nov 2001
    tk421 has the force, certainly for IE6, not tested with other browsers.
    I've found IE will often resume at the break after you've lost the connection if you go straight back, do not pass go, do not collect £200, just re-download. :D
