I have forgotten a memo - i need help
Discussion in 'Tech Support' started by disturbed13, 31 Jul 2025.
  1. disturbed13
    disturbed13 Minimodder
    28 Nov 2008
    Im trying to get a Raid 5 array going... i have an old High Point RocketRAID 230xPM controller that is seeing all 4 2TB HDDs (showing 6000.94GB - 6TB). It says that its status is Uninitialized... and the controller doesnt have any options to fix it... that i can tell. It is running on a Windows 7 Home Premium, has 8GB of ram and all its doing is acting as a server...
    what am i forgetting to do?
    any thoughts would be greatly appreciated
    Thanks
  2. David
    7 Apr 2009
    Can you see the uninitialised volume in disk management?
  3. disturbed13
    28 Nov 2008
    yes, i partitioned the volume and it shows 5 and some change TB (close enough). my understanding is that if the array is uninitialized it does not have the parity bit and thus its redundancy for the whole purpose of a RAID 5 array.
  4. gamesaregood
    gamesaregood Modder
    8 Apr 2004
    Is it not a case of initializing the disk in windows and formatting it?
  5. Gareth Halfacree
    4 Dec 2007
    Did you remember to do step one of "creating RAID arrays" in the manual - initialising the disks in the RAID card BIOS (not the motherboard BIOS)?
    If not, delete the array, initialise the disks, recreate the array and you'll be golden.
  6. disturbed13
    28 Nov 2008
  7. Gareth Halfacree
    4 Dec 2007
    D'you see the tabs across the top of the screen? Create, Delete, and so on? Do you see the one at the very right, Initialize? That's what you need, according to the manual.
    Delete the array. Press the Right Arrow key until you're on Initialize (not Create, not the Background Initialization in the Create menu, the Initialize across the top) and hit Enter.
    That'll let you initialise the disks, *then* you can go into Create to make your array.
    To quote The Fine Manual:
    Arboreal likes this.
  8. disturbed13
    28 Nov 2008
    please enjoy the irrefutable evidence that the instructions in the manual does not work and gets me back to square 1
    thanks for your time and patience
  9. Gareth Halfacree
    4 Dec 2007
    Well, that's... weird, innit? The only other thing I can think to try is to zero the disks so they're uninitialised again then try again.
    (This is one of the reasons I recommend against hardware RAID...)
    EDIT:
    Aha! Here we go!
    Sauce.
    Turns out you can't finish the job in the card BIOS, you need to install the software! (Why that information isn't in the section on creating an array... well, I assume Highpoint hates its customers.)
