I having trouble with install it
Discussion in 'Tech Support' started by carlo67, 18 May 2008.
  1. carlo67
    carlo67 What's a Dremel?
    6 Oct 2006
    hi I have the WordPerfect Office X4 and vista.
    I having trouble with install it .
    I am getting error..
    2203.database: C:\Windows\Installer\554c6d.ipi. Cannot open database file. System error -2147287035
    carlo:wallbash:
  2. Golygus
    Golygus Minimodder
    9 Oct 2003
    I don't use corel, but have you tried running the installer as an administrator?
    Also, make sure your .Net is up to date.
  3. Hazardous
    Hazardous What's a Dremel?
    21 Jan 2004
    You might also want to try installing it after booting into safe mode?
  4. carlo67
    6 Oct 2006
    I tried running the installer as an administrator YES
    I installed on xp it worked ok.. it won't install it on vista ultimate
  5. Golygus
    Golygus Minimodder
    9 Oct 2003
    Can you install any other apps that use MSIs - eg alcohol 120% ?
  6. culley
    culley What's a Dremel?
    12 Jul 2006
    Are you installing it from a CD/DVD? If not maybe the .exe is currupt.
  7. Krog_Mod
    Krog_Mod What's a Dremel?
    23 Sep 2003
    he said it worked on xp so the .exe wouldnt be corrupt. It just might not be compatible with vista yet. If you can't get it to work maybe try OpenOffice It's pretty decent and I think it supports the Word Perfect file formats too.
  8. EnglishLion
    EnglishLion working for the good of mankind...
    2 May 2008
    I'll second OpenOffice being good. I use it all the time even though I have MS Office too - I only really got MS Office for Outlook!
  9. monkeybone
    monkeybone What's a Dremel?
    28 Jan 2005
    Try changing the permissions on the SYSTEM account to read/write/modify on the C:\Users\Username folder to see if this works.
    Or it could also be a permission issue on the C:\Windows\Installer folder.
    Permissions should be something like this below:
    Everyone - Read & execute, list folder contents and read
    SYSTEM - Full control
    Administrators - Full control
    The Administrators group should be the folder owner.
    Hope this helps.
    Monkeybone
  10. carlo67
    6 Oct 2006
    I done this but it still same. have you got other ideas?
  11. Denis_iii
    Denis_iii What's a Dremel?
    1 Jan 2007
    this is what you do, don't use Vista :) wait for SP2 or even better Windows 7
    and 2ndly, go openoffice, and unlike coral office or office 2007 you'll have loads of support
  12. MrWillyWonka
    MrWillyWonka Chocolate computers galore!
    25 Jul 2004
    Although it should work on vista, it may be worth a try to try installing it in XP mode as it has worked for me on two occasions in the past.
    Go to the CD and open it, right click the the install icon and got to Compatability, in Compatability mode tick "Run this program in compatability mode for:" selecting Windows XP (Service Pack 2). Even though its a read only disc Windows will save this option.
    Hopefully you can install the program. Let us know.
  13. Golygus
    Golygus Minimodder
    9 Oct 2003
    it works fine on vista. I tried when i first read the post. I believe that its a localised problem.
    It used Microsoft's own installer which is why I asked if any other MSI packages work - It would help to know...
