Build Advice I Keep Getting An Electric SHOCK! 0_0
Discussion in 'Tech Support' started by Judge Zetsumei, 29 Jan 2010.
  1. Judge Zetsumei
    Judge Zetsumei What's a Dremel?
    8 May 2009
    Every time I come home from work and first touch my mouse I get an electric shock!:eeek: It's static I assume but why? It seems to have started since i got my new case (Silverstone FT02). I've noticed the window on the case also seems to get quite static.
    Is it something to do with grounding? I know almost nothing about that sort of thing. What could I have done wrong when I installed the components into my new case. All I did different was not use those red cardboard washer things on the motherboard because I read you don't need them but I'm starting to wonder if that's correct.... :worried:
    Oh and my psu has a grounding wire, I screwed it to one of the standoffs under the motherboard, is that right?
  2. thehippoz
    thehippoz What's a Dremel?
    19 Dec 2008
    sounds funny but try a different pair of shoes.. some shoes will turn you into pikachu
  3. Judge Zetsumei
    8 May 2009
    Are you serious? lol
  4. Teelzebub
    27 Nov 2009
    What make of psu is that tbh I'v never seen a psu that had a separate ground wire ??
  5. Judge Zetsumei
    8 May 2009
  6. thehippoz
    19 Dec 2008
    yeah serious.. have a set of penny loafers, anytime I wear them I shock myself everywhere.. only happens with those shoes though :D
  7. 13eightyfour
    13eightyfour Formerly Titanium Angel
    9 Sep 2003
    Me neither, What mouse do you have?
  8. Judge Zetsumei
    8 May 2009
    i have this mouse
  9. mjm25
    mjm25 What's a Dremel?
    19 Jan 2009
    lol shiny.
    if it makes you feel better i got a shock the other day when i put my hand on another computer while i was already touching another one... not sure why that happened and didnt affect me when i was touching anything else metal. but i could feel the electricity buzzing all the time i had my hand on both. very very odd. anybody know why that happens? :/
  10. matty4467
    matty4467 ...
    21 Aug 2009
    Hmm, you sure its your mouse? is it's case plastic? If so im not sure how this could happen?
    Might it be your chair? I know that in some of the room at my school, the chairs give out static shocks.
    Matty
  11. Judge Zetsumei
    8 May 2009
    The thing is, this only started happening since I installed my components in my new case. Nothing else has changed but I didn't get static before :\
  12. Jenny_Y8S
    Jenny_Y8S Guest
    Have you noticed anything else strange recently? Really good hearing? Super strength? The ability to shoot spider silk out of your butt? The ability to turn the TV channel over just by thinking about it?
    Just wondering you see, your super power could be electricity based!
    Don't worry, an electric super power is really cool. Mine's is based on tomoatoes which is really lame!
    Good luck with the costume.
    Oh and if it isn't a new budding super power then check all your case connections, it sounds like you may have a dodgy earth.
  13. Teelzebub
    27 Nov 2009
    I would be tempted to try another psu just the same .
    Have you tried disconnecting the ground wire .
  14. Judge Zetsumei
    8 May 2009
    well im about to buy a nice i5 upgrade today so i'll leave the ground wire off. Do i need to use those silly little red cardboard washers on the stand offs?
  15. Teelzebub
    27 Nov 2009
    I never use those washers .
    Have you tried it without the ground wire yet ??.
  16. PureSilver
    PureSilver E-tailer Tailor
    16 Dec 2008
    I always zap myself (static buildup from the Uni desk chair and my jumpers) whenever I touch the case. Try different shoes, or maybe a different coat or something?
    Never seen a PSU with an earth wire, but that's nothing do with it.
  17. droitwichdosser
    droitwichdosser What's a Dremel?
    25 Apr 2009
