Cooling I need a 6600GT water block
Discussion in 'Hardware' started by sk8ter646, 10 Oct 2005.
  1. sk8ter646
    sk8ter646 Minimodder
    4 Oct 2005
    im about to install my first water cooling kit and am looking for a good block for my GFX card and if i use a universal block will i need to put heatsinks on the ram on th card
  2. Shadowed_fury
    Shadowed_fury Minimodder
    21 Nov 2003
    Might wanna put if its AGP or PCI-e, since it actually makes a difference with the 6600gts.
  3. sk8ter646
    4 Oct 2005
    oh yeah i forgot that its AGP and its made by sparkle
  4. severedhead
    severedhead What's a Dremel?
    19 Dec 2002
    The AGP cards have the AGP bridge chip to cool too which is something else to take into consideration.
  5. matrixops
    matrixops What's a Dremel?
    17 Feb 2005
    When I watercooled my XFX AGP 6600GT, I used the Swiftech MCW-50 waterblock. It required me to modify the hold down to clear the bridge chip, but otherwise looks good. Swiftech has released a new version which might have an altered hold down.
    Here is a picture of the modification and installation:
    My temps haven't broken 50c yet, even after hours of BF2.
    If you do some research on this card, it looks as though >70c on Air can be normal.
    Just my opinion though.
    MatrixOps
  6. jaguarking11
    jaguarking11 Peterbilt-strong
    10 Dec 2003
    The maze 4 block should work on the 6600gt but I would consider making a larger custom heatsink for the bridge or maybe making a waterblock for it.
    FYI my card dosent go over 41c load 39idlel even though I have a presscott in the loop but its a pci-e card that dosent need a bridge. Consider maybe getting one of those pci card coolers and undervolting them for silence.
  7. sk8ter646
    4 Oct 2005
    ok then ut are there no specific coolers for this card
  8. J-Pepper
    J-Pepper Minimodder
    20 Jul 2004
    if you are going small bore... i.e. 8/6mm or 10/8mm then Aquacomputer do a specific 6600GT AGP all-in-one GPU and memory cooler.
  9. matrixops
    17 Feb 2005
    Living in the states, I had never heard of that water block J-Pepper. That is one nice looking piece of hardware.
    MatrixOps
  10. phuzz
    phuzz This is a title
    28 May 2004
    I've got an aquacomputer 6600 AGP block that I'm trying to get rid of (water + 6600 = teh bad -> new 6800), pm or mail me if you're interested...
  11. sk8ter646
    4 Oct 2005
    cool will it fit my 6600gt and how much do you want
  12. phuzz
    28 May 2004
    emailed you...
