So I am looking to build a computer, and am fine with the hardware type stuff except for the starting point, the case! I was wondering if anybody could recommend a case or two with the following specs: - Small - Ability to fit in a full sized graphics card (or sli if poss) - Preferable ability to fit water cooling. - Less than about £60 if possible (though if you have a suggestion over that fits everything else well then please do suggest away!). Thanks very much
I can tell you an amazing case. Small, able to fit water, side mounting hard disk bays with quick release. Top 120 fan slot, 2 x 120 side fan slots, front blue led 120 fan cooling the hard disks. The case is amazing! http://www.ebuyer.com/172779-casecom-6788-all-black-case-km-6788-black It also has CPU cutout.
Thanks guys - Tangsters one is more what I am looking for (though pricier). Feathers that case just looks a bit big, though it does also look pretty good and really nicely priced!
The 1st and 3rd point don't really go that well together but I know that all of the corsair cases fit a h100 in, so they might be worth a look.
