Cooling I need a crossflow fan!
Discussion in 'Hardware' started by ickywu, 27 Aug 2006.
  1. Butcher9_9
    Butcher9_9 What's a Dremel?
    15 Sep 2006
    most case dont have enouph space between the mobo tray and the side of the case
    mine has about 10mm from case side to mobo tray and 17mm from case side to mobo so a 120x120x25 will not fit in the gapunless you mount it externally
    i used 4x 80x80x15mm fans
    the camera does not pick up uv as much as the human eye
    the fan blades are painted blue uv and the leds are uv so it looks purple blue to me and all the fans and leds have switchs
    cutting your mobo is not that hard or dangerous as long as you are not retarted and take out the mobo when you are doing it. a jig saw would work fine and would take less time/cutting discs
