I need a DECENT browser
Discussion in 'Software' started by DaveVader, 8 Aug 2008.
  1. DaveVader
    DaveVader Fast Action Response Team
    10 Aug 2007
    I used Firefox a lot but then it kept effing up on me, so I downloaded Opera and its so slow and resource hungry I'm getting fed up with it;
    so can anyone recommend a decent browser?
  2. Krikkit
    21 Jan 2003
    What's FF been doing? Is there a well-documented fix for it?
  3. DaveVader
    10 Aug 2007
    it keeps crashing on me and I couldn't be asked to try and sort it so I left it, but I will have a go with it and report my findings.
    I think it was just a generic "this programme is not responding, send error report?" etc. etc.
  4. theevilelephant
    theevilelephant Minimodder
    5 Jan 2006
    6 months ago i would have said opera but the last few updates have , as you've said, fecked it right up. I would say its worth trrying to sort out FF.
  5. Flibblebot
    Flibblebot Smile with me
    19 Apr 2005
    Especially FF3 if you haven't tried that yet.
  6. DaveVader
    10 Aug 2007
    yeah I had FF3, I will give it a blast again.
    Edit/Update:
    Happened once, closed FF, reopened, started a new session, happened again pretty much straight away.
    I may try to download it again.
  7. Flibblebot
    19 Apr 2005
    Make sure your profile has been deleted before you reinstall. Something in there might be the cause.
  8. BentAnat
    BentAnat Software Dev
    26 Jun 2008
    FF does that a LOT in my case as well... specially on the MS site, strangely enough... as a web developer, i normally go IE first, then FF. statistics show that on the sites i work on, 92.8% is IE and FF. 66% IE alone.
  9. DaveVader
    10 Aug 2007
    cheers, I will give it all a try when I can be asked
  10. andatche
    andatche What's a Dremel?
    11 Nov 2005
    I've always found Lynx to be about the best there is, especially for all this new fangled web 2.0 business. :)
  11. capnPedro
    11 Apr 2007
    ^ lulz.
    SeaMonkey? Flock?
  12. tm36usa
    tm36usa What's a Dremel?
    21 Jan 2004
    I had been running opera for the last couple of years after i got fed up with FF. A few weeks ago i downloaded K-Meleon to do some testing. It uses the same rendering engine as FF (Gecko) but i think its a hell of alot better. And im really surpised at how light it is. Usually i have 8-10 browser windows open with 5 or 6 tabs in each. In opera thats 300-400mb of memory usage where as in K-Meleon its using only 164mb as I type this. I may have just found something to replace Opera as my main browser. (I am missing speed dial a whole hell of alot tho)
  13. GoodBytes
    20 Jan 2007
    Firefox3 or Netscape Communicator for Windows 3.1 ;)
  14. lamboman
    lamboman What's a Dremel?
    25 Jul 2006
    If you are going to use Flock, you are likely to encounter similar problems, considering it basically a pimped version of Firefox (brilliant though, using it right now, and love it).
    As Flibblebot said, delete your old profile.
  15. kennethsross
    kennethsross What's a Dremel?
    29 Jul 2008
    Windows 3.1. Now we're talking. That was an OS! Never even bothered with Windows 95. Used 3.1 until Windows 98 came out, and I built a new PC.
    Nostalgia - nothing like it (even if it is a thing of the past:lol:)
  16. TheAbyssDragon
    TheAbyssDragon Gafgarion
    8 Dec 2005
    FF 3 has been buggy here and there for me as well. If it really bothers you that much, go back to FF 2.14 until the next update for 3 comes out.
  17. GregTheRotter
    GregTheRotter Minimodder
    9 Aug 2008
    w00t firefox works fine for meee.
  18. Akava
    Akava Lurking...
    28 Jul 2007
    Havn't had any really problems with FF3 tbh and so recommend it. But then, I don't use many addons so...
  19. cyrilthefish
    cyrilthefish What's a Dremel?
    15 Apr 2004
    Intersting how wildly different browser stats are on different sites:
    Current stats for August on my site (several of the www.iichan.net imageboards ;) )
  20. GoodBytes
    20 Jan 2007
    ok it is impossible that Konqueror and the rest is 0. That means that the dev's don't even use it.
    These stats are from their web site probably, same for the BentAnat
