I need a stable reliable mobo for a work station, but all I know is top end.....
Discussion in 'Hardware' started by Mother-Goose, 12 Jul 2007.
  1. Mother-Goose
    Mother-Goose 5 o'clock somewhere
    22 Jul 2004
    As you might have guessed, I am after a nice, stable, reliable C2D mobo, but all I really know about is the top end 680i stuff, which isn't what I am after for this comp. I know what components I am going to drop in, the mobo is the bit I am getting unstuck at.
    It will be partnered with a E6600 running at stock, it will NOT be oc'd.
    I was thinking DQ6 because it's feature rich and pretty good value for money, but I know the DS3 would be fine for it. I'd say £80 is the price limit and SLi is not required. I cannot seem to find the P5B deluxe on the scan site anymore, or the DQ6 for that matter, and those would have been my original thoughts.
    Just after suggestions really :)
  2. Guest-16
    Guest-16 Guest
    Intel boards like the 975X Bad Axe 2, or go to their website and look at their workstation offerings.
  3. cosmic
    cosmic What's a Dremel?
    6 Jul 2007
    If you like the DQ6, then why not look at some of the other Gigabyte boards around the £80 mark. I would go for the DQ6 myself - especially if its on offer this weekend
  4. fivecheebs
    fivecheebs Dont panic!
    19 Feb 2003
    I've built 3 machines around the DQ6, all have been very reliable so far, except for one that was DOA.
  5. Mother-Goose
    22 Jul 2004
    The DQ6 has suddenly become very hard to find, strange.
    I'll have a look at the bad axe boards bindi, I don't want to go totally work station, he does do a fair bit of multitasking and high res graphics (for adverts), but I know the intel boards are good. I'll have a browse and see what I come up with and list them here me thinks.
  6. BUFF
    BUFF What's a Dremel?
    25 Mar 2005
  7. Fr4nk
    Fr4nk Tyrannosaurus Alan !
    12 Mar 2005
    How about the much loved P5N-E SLi's ? only £70-80...
  8. Bbq.of.DooM
    Bbq.of.DooM Custom User Title
    12 Feb 2005
    p5k vanilla
  9. Deep-Blue
    Deep-Blue Part-time Overclocker
    1 Feb 2004
    As far as a reliable, future-fit board goes, i can't help but praise the EVGA 650i Ultra board. Excellent warranty, excellent basic features, stable, fast stock, faster overclocked.
    There is a review on the main site, plus plenty around on the net, all of which backup what im saying!
    I'm running one with the aforementioned E6400, 6Gb of OCZ 667Mhz @ stock (plan to get it back to 800mhz), and a quartet of 160gb Seagate drives, with a trust 7800gt. Its reliable, stable, and kicks ass on XP64 as im sure it'll do on vista64 of any 64bit flavour of linux.
    And it'll happily take quad core, and the new 1333mhz fsb cpus coming later in the year.
    I'll stop raving bout the board now, i think you get the picture :)
  10. tzang
    tzang Traditional Nutter
    7 Jun 2007
    Moving away from the world dominated with Asus, Abit and Gigabyte, if you are looking for a reliable workstation motherboard, may I suggest SuperMicro. It's pretty much unheard of in the gaming industry but in the enterprise industry (servers and workstations), they are rather common. You won't get any fancy colour coding or get fed with tons of features, however, if you want something very reliable along with great build quality, you cannot go wrong with SuperMicro.
    The PDSBE or C2SBE might be the model you want to look out for but they aren't easy to find. Prices are around £110 though.
  11. Mother-Goose
    22 Jul 2004
    I was thinking 650i would be a simple way to go as well, I am glad someone mentioned it.
    @ bbq, I can't find a P5K in any of the stores I'd want to use which is a bugger.
    @ tzang, thanks for the suggestion, I don't want to go *too* workstation though, I should have perhaps left that out of the description :)
  12. MilkMan5
    MilkMan5 Yeah man...
    11 Jul 2007
    If you ant a good reliable workstation board, then stick to Intel branded motherboards.
    Speak to anyone who has honestly tested Intel boards, and you will know that its the most reliable boards you can find.
    But don't expect any fancy features.
    The Gigabyte motherboards now use Solid-capacitors and Heat-pipe techonology - No fans.
  13. Bbq.of.DooM
    12 Feb 2005
    Also try Foxconn boards. Foxconn makes intel boards.
    Maybe a P5b ?
  14. Fophillips
    Fophillips What's a Dremel?
    9 Oct 2006
  15. specofdust
    specofdust Banned
    26 Feb 2005
    P5N-E's are NOT reliable. They're flakey as hell at times. Mine took about 3 hours to get booting first time around, I just had to keep cycling power and doing random crap to get it to work. They're super duper overclocking mobos for the money but definitely do not buy one if you're after stability.
  16. SPQQKY
    SPQQKY Evil Modder
    7 Jul 2007
