Electronics I need an digital potentiometer
Discussion in 'Modding' started by Bricolo, 22 Feb 2002.
  1. Bricolo
    Bricolo What's a Dremel?
    22 Feb 2002
  2. specialk
    specialk What's a Dremel?
    5 Feb 2002
    Just buy a D2A (digital to analog) converter and use it with a variable voltage regulator for high loads. Most (if not all) digital pots can sink only a few microamps, it's a waste to try to put a load on them. They are only good for reference voltages.
    -special [k]
  3. Bricolo
    22 Feb 2002
    thanks for your help
    can you tell me wich D2A I should use?
    I know a few things in electronics, but absolutely nothing about digital and com port communication
