I need help for my BCS test on Monday ...
Discussion in 'Serious' started by [DE]FreD_S, 20 Sep 2003.
Thread Status:
Not open for further replies.
  1. [DE]FreD_S
    [DE]FreD_S Certified Specialist of Awesomeness
    6 Jan 2002
    Hi Everyone !
    As stated above, I need some help for my Basic Computer Sciences Test on Monday ... I managed to get some tests the prof. has already given out and as most of the questions are the same, I suppose these will also be asked in my test ... NO ! This is not cheating ! Every Proffessor hands out older tests for us to have a look at ...
    So here goes ... most of these things we all know, but how do you define them properly in order to make your Prof. happy ? Now I'm going to write what I think is right, if I know it and I'd like to ask you to either correct me, or fill in the answer if I wasn't able to do so myself. And yes I have looked at Sausage.net and used worthless Google ... THANK YOU VERY MUCH in advance !!!
    1. What is a file ?
    - A unit of Information stored on a Computer
    2. What is a directory ?
    - A collection of files for organisational purposes. A directory is itself a file and can contain other directories.
    3. What is a drive ?
    - A device to store and retrieve data. Two sorts : read & write and read only. Two types of acces : random and sequential.
    4. What is a window ?
    5. What is Menu Bar ?
    - The Startbar for example. Contains the most commenly used applications and systemcontrol programms ?
    6. What is an aplication-window ?
    - The user interface of an aplication ?
    7. What is a byte and how much information can be shown ?
    - A byte is a collection of bits, typacally 8 bits. 256 informaions can be shown.
    8. What is a break in word ? What are the characteristics of a break ?
    9. What is a section in word ? Why is it a section and not a break ?
    10. Write a functiondeclaration in C.
    - I don't know s*** about C ... :waah:
    11. What is a printer in C ?
    12. Given : a with "point to float". Write a command that gives float b the value of a.
    13. What categories of loops are there in C ?
    14. Which value do d and i have after going through the following programmsentences ?
    int i;
    double d;
    d6;
    i=7;
    =i/d d=i*d
    - I'd say d would be 42 and i would be 1,16 ?
    15. What is a pointer in C ? Given : variable a pointer to double. Write a programmm that gives the double-variable b the value of a.
    - Would this be right ?
    include <stdio.h>
    void main
    double a
    a=5
    b=*a
    printf("a%lf, a")
    printf("b%lf, b")
    printf("*b%lf, *b")
    16. What is the difference between a pointer and a vector in C ?
    - A Vector has bigger memory than a pointer ?
    Now if you've made it this far, I'd really like to thank you ! Those are just 16 questions out of 100. Most of them are probably easy, but sometimes I just don't know what to write ... maybe you all know what I mean. In any case a big THANKS for your help !
    Cheers
    [DE]FreD_S
  2. [DE]FreD_S
    6 Jan 2002
    Not anyone ? :waah: I'll post the C stuff in the programming forum aswell, maybe someone there will be able to help me at least in C ... I need that C stuff ... :wallbash:
    Cheers
    [DE]FreD_S
  3. RTT
    RTT #parp
    12 Mar 2001
    Not really the place for this :)
Thread Status:
