Electronics i need help identifying wires out of the Psu
Discussion in 'Modding' started by mephistopeles, 28 Aug 2004.
  1. mephistopeles
    mephistopeles What's a Dremel?
    24 Aug 2004
    i just started modding :dremel:
    i need to know the the colors and wolt of each color
    i don't want to be plugging a led into a 12v wire by accident
    thanks to anyone who helps me out
  2. TheAnimus
    TheAnimus Banned
    25 Dec 2003
    Standard Molex, that has one red, 2 black, and one yellow.
    red = 5v
    yellow = 12v
    black = GND
  3. pdaoust
    pdaoust What's a Dremel?
    23 Apr 2003
    If you're also asking about the 20-pin Molex connector on the motherboard, that's a little complicated, partly because the colours are often different depending on the power supply manufacturer. You can find a diagram of an ATX power supply connector by doing a Google search for 'atx power supply pinout'. You'll probably need to disregard the colours in that diagram, though; they match the colours in my current power supply, but not my old one.
  4. ehrnam45
    ehrnam45 What's a Dremel?
    5 Jul 2004
    check out formfactors.org for detailed specs on standardised power supply interfaces, case dimensions, etc.
