I need help pls
Discussion in 'Hardware' started by hunterx, 30 Jan 2005.
  1. hunterx
    hunterx What's a Dremel?
    30 Jan 2005
    i just bought a new motherboard i hook it up then i notice that the motherboard has no VGA port,so i get on a tech forum site and ask if i can just use my graphics card vga port.It was agreed that yes i could,so i do so but when i turn my comp on my screen stays black and the light goes from green to orange. then i get a message that says"no signal input,or cable disconnected".ive tried two different cards and monitors and it says the same thing......pls help me :waah:
  2. Guest-16
    Guest-16 Guest
    Hi, welcome :)
    1) What motherboard did you buy?
    2) What graphics card do you have?
    3) You install the graphics/cables correctly?
    4) Install ram/cpu correctly? Power - both plugs?
  3. hunterx
    30 Jan 2005
    motherboard: NF2 ultra infinity with nvidia chipset
    Graphics card: nvidia geforce fx 5200 ultra 128 mb
    all the cables are correct i think, the computer comes on just fine everything runs but i get that black screen and then that message...
  4. Highland3r
    Highland3r Minimodder
    25 Jul 2003
    Oooo its an infinity... yea thats normal, just prod power ~ 13 million times and it'll boot in the end.... You're waiting for me to tell you I'm joking arent you....
    :rolleyes: :rolleyes:
    Thats one way to fix, another is to toally power cycle the board, switch pc off, turn psu off, switch off at plug, then turn on again.
    Also, try clearing the cmos. Switch off at psu and plug, Set jumper to clear, remove CMOS battery, wait a MINIMUM of 30 secs, replace battery, jumper to default, on at all, on at psu and boot :)
  5. Kameleon
    Kameleon is watching you...
    29 Apr 2003
  6. Guest-16
    Guest-16 Guest
    The message is a default one the monitor will display when it detects no signal or standby signal from the graphics card which implys a power problem with your pc.
  7. hunterx
    30 Jan 2005
    this is quite depressing im still working on it ill update
  8. Highland3r
    25 Jul 2003
    Its the random no boot issue with the UI :) Mine does it all the time, monitor just sits in standby...
    Looking at the LED's on me NIC tho, it does seem like a powerup issue....
  9. hunterx
    30 Jan 2005
    i bought a 500watt power supply so i wouldnt have a power issue cause nvidia geforce ultra 5200 are so damn power hungry
  10. hunterx
    30 Jan 2005
    and u fix it by doing what?
  11. Guest-2867
    Guest-2867 Guest
    :hehe:
    (sorry m8)
    By the way, what brand PSU did you buy ?
  12. hunterx
    30 Jan 2005
    honestly it came with the case i bought soooo its probably pretty cheap :D
  13. Guest-16
    Guest-16 Guest
    Ah, fair enough.
    500W PSU for FX5200 :D total overkill im afraid. Ive used a 350W to run a 6800GT.
  14. hunterx
    30 Jan 2005
    how do i do this?
    3) Raise vAGP. This has shown results for quite a lot of users, vAGP of 1.6 or 1.7v seems to make the boards post more frequently if the cold-boot problems are severe, or make them go away altogether. Results have also been obtained when increasing vCore/vDIMM.
  15. Highland3r
    25 Jul 2003
    Its in the top right menu in bios.
  16. Ben
    Ben What's a Dremel?
    11 Aug 2003
    edit :: ga beaten to it.
  17. hunterx
    30 Jan 2005
    i cant even get in bios.....so thats no good for me
  18. Highland3r
    25 Jul 2003
    Did you try power cycling and clearing the cmos as suggested?
    Also boot with a single stick of ram in slot 1
  19. Guest-2867
    Guest-2867 Guest
    rofl, just keep cycling the power until it fires up, if that fails just fiddle with stuff till it does lol, it is known to be quite a tempromental motherboard until you get it up and running properly through the bios settings
    cross yer fingers lol
  20. hunterx
    30 Jan 2005
    failure but ill keep at it
