Modding I need the link to a molex extractor tool please :(
Discussion in 'Modding' started by orangejulius, 9 Sep 2003.
  1. orangejulius
    orangejulius What's a Dremel?
    26 Jun 2003
    ive spent like 30 mins looking for a link here maybe im blind but please some link me to one and maybe put it in the FAQ as molex extractor tool please make it so much easier to find.
  2. Hamish
    Hamish What's a Dremel?
    25 Nov 2002
    lol you dont need a tool, you can just use a small screwdriver or anything small and pointed :)
  3. orangejulius
    26 Jun 2003
    I just want the tool :) and my sight is bad close up so its really hard for me to focus that close :) and dont wanna end up breaking one of the connectors
  4. tok3n
    tok3n What's a Dremel?
    20 Apr 2003
  5. Wreckless
    Wreckless What's a Dremel?
    14 Aug 2003
  6. Cipher_UK
    Cipher_UK What's a Dremel?
    12 Mar 2003
    I use a small piece of brass tubing i have left over from a R/C Plane glued into a dowel handle.
  7. sirgeoph
    sirgeoph What's a Dremel?
    19 May 2003
  8. thw01f
    thw01f What's a Dremel?
    13 Sep 2003
    Try this idea. A 3.5mm mono plug, remove tip (or + terminal) with pliers and your left with the base (or ground). It also has the plastic surround screwed onto it to give you something to hold onto. Fits female molexs :) , releases both pins together and doesn't permanently bend them which can cause breakage
    me UV case :eeek: POWER and the GLORY
  9. flyboy -|-+
    flyboy -|-+ What's a Dremel?
    16 Sep 2003
    Radioshack sells a really good tool for 6.99
  10. Dogg
    Dogg What's a Dremel?
    14 Sep 2003
