Planning I/O Layout and Expansion Slots?
Discussion in 'Modding' started by That Bald Guy, 7 Apr 2009.
  1. That Bald Guy
    That Bald Guy Hi-Tech Redneck
    6 Apr 2009
    I'm sure this has been asked before, and yes, i did some searching, but to no avail...
    Looking at building my own case from scratch, and was wondering what people do for the I/O panel and Expansion slots. I know most mobos come with the snap-in panel, but what I am wondering, if any of the :geek:s on this forum have taken the time to draw up the back panel in Autocad?
  2. Fumduck
    Fumduck Have torch, will melt.
    5 Aug 2008
    No need. Goto www.formfactors.org and you can get all of the info you need.
    Aint standards great. ;)
  3. Cheapskate
    13 May 2007
    I chopped an old one out of an ATX case. I use that for measurements and tracing.
    There are several case models in the Sketchup Computer parts library. Check the sticky at the top of the page. There's a dxf conversion plugin for sketchup on the net somewhere.
  4. That Bald Guy
    6 Apr 2009
    I saw on one of the mineral oil PC builds where someone purchsed a rear panel that had I/O hole and expansion slots already cut. anyone know where I might acquire one?
  5. jhanlon303
    7 Sep 2006
  6. That Bald Guy
    6 Apr 2009
    Now that is a B-E-A-UTIFUL thing. Doesn't really show how it is mounted to the inside of a case tho, anyone have a pic of the back side? ooh, that sounds dirty... I wanna see your motherboard tray's backside....
  7. jrs77
    jrs77 Modder
    17 Feb 2006
    You can make your own. Not that hard with the measurments available. I've measured it once for an older project and it fits perfectly using those.
    http://www.robsinter.net/temp/ATX-backplate.EPS
    Best thing about it is, that you only need to bend the one section 90° out.
    Hope that helps.
  8. talladega
    talladega I'm Squidward
    18 Aug 2007
    how do I open that .EPS file?
    edit: NVM, I got it.
