Disaster I Ruined The top My Lian Li!!!
Discussion in 'Modding' started by The Punisher 2000, 4 May 2002.
  1. The Punisher 2000
    The Punisher 2000 What's a Dremel?
    21 Apr 2002
    I had some type of crud on top of my Lian Li so as i was taking it off sssssssssssccccccccccccccrrrrrrrrrrrraaaaaaaaaaaaattttttcccccccccccchhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhh. Oh it was great let me tell ya. Anyway they aren't big areas where i scrathced just little areas with quite a few tiny scratches. Any body know how to temporarily fix em. I mean i might be having some cuts with a water juet done to the top panel from a person i know. He is gonna cut The Punisher 2000 into the top and inside the Zeros in 2000 a punisher skull logo will be in there. But for right now I have to look at my dumbasses job on scratching my Baby. Anyway anyone know how to fix it or at least for temporary solution.
    T[H]anks.
  2. Digitalblueshift
    Digitalblueshift What's a Dremel?
    12 Feb 2002
    you could try sanding with really fine sandpaper, 600, 1000, 1500, 2000, rubbing compound. Its a lot of work but if your not getting it cut out soon you might want to. That sound bad, I freak when I scratch my $60 case.
  3. Lazy
    Lazy Meow?
    13 Nov 2001
    you could try and fix it so that the area you cut out includes the bit that it scratched. I know how you feel, i was putting my neon string in and got superglue on the bezel of my 4 day old chieftec dragon. It went white and i had to paint over it but the paint i used was a different shade of silver.
  4. Stew
    Stew Disgruntled Postal Worker
    6 Mar 2002
    can you not use brasso to fix scratches as seen as its a metal case?
  5. Lazy
    Lazy Meow?
    13 Nov 2001
    dunno but you could always buy a new one :D
  6. ug_the_caveman
    ug_the_caveman What's a Dremel?
    31 Mar 2002
    I think it'll probably be a job of cracking out the sandpaper...not sure about brasso though. It'll take some work but should be worth it when done...
    Ug :)
  7. bAnTAi
    bAnTAi What's a Dremel?
    19 May 2002
    if you have enough time, you could sand off the entire case to get to level of the scratches.....helplful hints from bAnTAi
  8. Behemoth
    Behemoth Timelord in training
    1 Nov 2001
    Scratched my lovely black Global Win 802 3 times :( First time looks real obvious, just about everyome can see it, other 2 scratches you reallyhjave to look hard for, but I know where they are :(
  9. acron^
    acron^ ePeen++;
    15 Oct 2001
    i scratched the window in my dragon full tower while trying to replace the etch and then my DAD put a nice scratch on the side of it as i was moving it.
  10. Gandi69
    Gandi69 Like to get busy wit fizzy..
    17 Jul 2001
    As soon as I opened the box to my Black GW802, I managed to scratch the top slightly with my fat carpet cutting capable stanley knife ('THE' box opener hehehe). Cant see the scratch now due to the junk on top of the case lol.
  11. Opticalwares - NDI
    Opticalwares - NDI What's a Dremel?
    27 May 2002
    [​IMG] Yes, thats what you get when you let your dad cut your top window :miffed: :miffed:
  12. christiaanm
    christiaanm What's a Dremel?
    24 Feb 2002
    muhahah
    yes, i find this really funny, i guess you can order a top alone for the lianli models, :dude:
