i think i just killed a mobo
Discussion in 'Hardware' started by lord nicon21, 2 Sep 2005.
  1. lord nicon21
    lord nicon21 sexy *******
    29 Sep 2003
    hi guys i changed the Clock speed to 200MHz and saved and exited and now it wont boot and i nothinking comes up on screen so i can't get in to the bios to change it back. i rest the CMOS but still nothing.
    can anyone help me out to what to do next :duh: :duh:
  2. Pie_uk
    Pie_uk British beef, in Britain
    6 Apr 2005
    try bootin on one stick of mem, try taking out gfx card then put it back in, or you could always remove the battery for 5 secs
  3. Lowtryx
    Lowtryx What's a Dremel?
    1 Sep 2005
    Are you getting a display? For example, does your monitor kick on during 'bootup'?
    Do you have any boot disks?
    Is the hard drive functioning properly?
    I just went through this sort of problem the other day.
  4. Fr4nk
    Fr4nk Tyrannosaurus Alan !
    12 Mar 2005
    umm.. you tried the Cmos jumper/button? :duh:
    -Frank
  5. lord nicon21
    29 Sep 2003
    yup rest the Cmos by the jumper and i allso took the batt out.
    i'v taken it all apart left it for a bit then tryed again
    no hard drivs on at this time as i don't get any thing on screen. ie boot info or anything.
    the monitor light comes on which means there is stuff going to it but its blank..
    do you think i might of killed the CMOS :jawdrop:
  6. DougEdey
    5 Jul 2005
    I think what he means is,
    "Is the jumper back in its right place?"
    check the diagram as this has happened to me before
  7. lord nicon21
    29 Sep 2003
    yeah its back :thumb:
  8. DougEdey
    5 Jul 2005
    Back as in working?
  9. lord nicon21
    29 Sep 2003
    no sorry "Is the jumper back in its right place?" yes it is
  10. DougEdey
    5 Jul 2005
    Which board are you using?
  11. lord nicon21
    29 Sep 2003
    its a MSI K7N2G which is't really on there site which sucks :duh:
  12. DougEdey
    5 Jul 2005
  13. Leeum
    Leeum What's a Dremel?
    16 Feb 2004
    Sounds like you've corrupt your BIOS. You need to find someone with an MSI K7N2G who is willing to hotflash your chip. The best option is to RMA it, if it's out of warranty you're out of luck i'm afraid :(
  14. lord nicon21
    29 Sep 2003
    thats the one but i only have 2 IDE and the heatsink is fanluss and no SATA but other than that yeah lol
    and can't get in to bois so can't change clock speed
  15. DougEdey
    5 Jul 2005
    Have you tried a different CPU?
  16. lord nicon21
    29 Sep 2003
    yeah i have 2 but i don't know if they work :sigh:
  17. Fr4nk
    12 Mar 2005
    So when you saved your settings in the bois and restarted, did the pc make a long beep? or was thier nothing?
    -Frank
  18. lord nicon21
    29 Sep 2003
    i think it was nothing
  19. Fr4nk
    12 Mar 2005
    Well if its nothing then something is probably dead :( Since the comp will ushally beeps if the settings arent correct or unbootable.
    So you might wanna rma or get a new board OR see if you can test your other componants on another mobo.
    -Frank
  20. Pie_uk
    6 Apr 2005
    yer i had the same prob with the abit board it happend after flashing the bios, then i got syptoms your saying:(
