Displays I think one of my monitors is dead...
Discussion in 'Hardware' started by adam_bagpuss, 24 Aug 2009.
  1. adam_bagpuss
    24 Apr 2009
    ok heres whats gone down so far, looking for suggestions on next step or just confirming its dead.
    monitor will not display any picture. managed to get it to flick on for about 0.2 sec then off again. last few attempts got nothing.
    tried these things to get it to work:
    1) tried all 3 inputs, analog 1-2 and DVI.
    2) tried 3 different cables, DVI - DVI/VGA and VGA
    3) attempted this on 2 laptops and my desktop.
    4) switched power cable.
    now when i switch input i can get a solid green light on display panel indicating im on the right input but nothing is displayed at all. When im on the wrong input it goes green then amber.
    any help appreciated
    ooo monitor is a Viewsonic 171b and its about 5-6 years old.
    cheers
    Adam
  2. Elton
    23 Jan 2009
    Could be a dead main board or inverter.
    Have you tried it on different computer?
  3. adam_bagpuss
    24 Apr 2009
    lol did you even read my post.
    tried on 2 laptops and 1 desktop
  4. kenco_uk
    28 Nov 2003
    Sounds like it's at death's door. If you're handy with a soldering iron, it should be easily repairable, I recall it's only a couple of components that need changing (I can't remember which though, sorry). Either that or get a new one.
  5. Burnout21
    Burnout21 Is the daddy!
    9 Sep 2005
    hook it up in a dark room, as if anything is fine, and use a torch close to the screen to see if the panel is still active, if you can see icons, etc is the backlight thats gone.
    If not then possible the panel has gone...
    Note its not as easy as it sounds to get this trick to work so take your time.
  6. Elton
    23 Jan 2009
    The image will be quite faint to be put simply.
  7. NightrainSrt4
    NightrainSrt4 What's a Dremel?
    25 Dec 2007
    I just want to mention that I have fixed a few LCD's with similar issues as mentioned, and each time it has been slightly bulging capacitors that was the issue and not the backlight itself. A few minutes with a soldering iron and replacement caps and they have been fixed. Just because the bulb is not lighting does not mean that it itself is what is wrong; every time I've seen that issue it has been the capacitors on the board.
  8. adam_bagpuss
    24 Apr 2009
    meh its ok, i can solder but dont have one to hand really. its old anyway.
    ill call it dead i think.
    not to worry not my main monitor just an additional i had.
    thanks for the input though
