Disaster I wanna cry. 320 gigs out the window.
Discussion in 'Modding' started by jackjr, 8 Jun 2005.
Thread Status:
Not open for further replies.
  1. jackjr
    jackjr What's a Dremel?
    27 May 2005
    So I'm sleeving my power cords in my big machine. Not really a mod, per se, just trying to do some tidying up inside the box. Note to all - make sure you have the molex connectors wired up properly when you put everything back together. I wasn't paying attention and wired it up backwards ( I think, still have to investigate. Flicked on the power to the box, and watched the dreaded blue smoke come pouring out of the drive bay. Needless to say, I've got a pair of 160 GB hard drives that are useless now until I can find replacement circiut boards. I think the drives themselves are fine, just have to replace the boards. Seagate is going to send a replacement for one drive, but the other is OEM and not supported.
    Not a happy day for me yesterday. 320 gigs down the toilet, hopefully only for the time being. :wallbash:
  2. RTT
    RTT #parp
    12 Mar 2001
    Ouch :(
  3. jackjr
    27 May 2005
    you better believe it... I was not happy when I left work yesterday. :duh:
  4. ElThomsono
    ElThomsono Multimodder
    18 Mar 2005
    Strange, I did the exact same thing, but I got away with frying one empty (read: brand new) drive.
  5. shroom
    shroom What's a Dremel?
    6 Aug 2003
    Ahhh a prime example of why I <3 seagate. The problem was entirely your fault, but they are glad to help you out regardless.
  6. Shadowed_fury
    Shadowed_fury Minimodder
    21 Nov 2003
    Dude, ouch, shame to hear that.
    Yep, Seagate Rock!
  7. jackjr
    27 May 2005
    The nice thing is - Seagate is going to advance ship me a drive, so I'll be able to pull the circuit board off the replacement, load it on the defective, get my data back (pray pray pray) and be back in business in no time with that one. The WD is going to take a little more doing. If I have to get another WD from ebay or something, I don't care. The data that's on the drives are way more important that the physical drives themselves. Fortunately, I have a backup of some, but not all, the data.
  8. jackjr
    27 May 2005
    Absolutely.. I used to love WD drives, but Seagates support has definitely been a godsend at this point.
  9. Ghlargh
    Ghlargh What's a Dremel?
    16 Nov 2003
    Put up a wanted ad on ebay for WD drives of the exact type and size of the one you have, and say that it doesn't matter if there are damaged sectors or drop damage to the drive, just as long as the controller is not screwed.
    Too bad it wasn't an IBM 40gig or 80gig, i have one each of those that i screwed up window mods for, see image for more information: It was allready broken from a bad window mod, i just had some fun.
  10. jackjr
    27 May 2005
    Wonderful idea.. done. :rock:
  11. foxx
    foxx What's a Dremel?
    5 Sep 2004
    I think this is one of the most mistakenly thing done in mods. But I am glad your not giving up on the drives and getting more controler boards. Save the drives!!
  12. CyberSol
    CyberSol 1337 Pants
    18 Oct 2004
    OUch! Been here, done that! I hope the swap works for you!
    Btw, I like that "Window" on the hard drive, But what did you do to it???
  13. Ghlargh
    16 Nov 2003
    I screwed up the window mod, the harddrive didin't clear self check, so i smashed it 15 times into a concrete floor until the platters broke. IBM's 80gig drives use glass platters...
  14. Firehed
    15 Feb 2004
    Hope you can recover the data. Best of luck - you'll need it. For all you can be sure of, the motors could have been fried too :eeek: :waah:
  15. P2D
    P2D 99.999% Pure Spam!
    26 Mar 2004
    i`d be gutted! only got an 80gb hdd atm, getting a 160gb soon tho (hopefully)
  16. Ghlargh
    16 Nov 2003
    I wouldn't think the motor or actuator coil (reader arm) would be burned, that would take some serious current, not sure the connectors and chips on the board could supply that current.
    But burning the data bus translator that is mounted inside the drive, usually on the reader arm, is a real possibility :(
  17. wolff000
    wolff000 I am here to steal your secrets.
    26 Apr 2005
    that bites, hope just replacin the boards does it for you. please be sure to post the results.
  18. woodjamin
    woodjamin What's a Dremel?
    2 Jan 2005
    i did the same exact thing. had a nice 160gb for a liong time almost full.. sleeved my whole powersupply and the next thing i know my 160 is dead. i reversed the red and yellow wires. >.<
  19. fof gwada
    fof gwada What's a Dremel?
    8 Jun 2004
    yeah i did that also i think a lot of people have
  20. Tulatin
    Tulatin The Froggy Poster
    16 Oct 2003
    it's just 320GB. I lost 2x250 due to one dying due to the 5v line slipping out (265GB data, flushio), an 80GB maxtor (just stopped spinning one day, and took it's array with it (95GB data, flushio). Plus i lost a 20 GB deathstar, (8 or so GB) and a 30GB maxtor (30 GB flushio)
Thread Status:
