I'm looking for a dvd standalone for about £100 it has to be able to do vcd and if possible multi-region I was looking at asda £89.99 one or richersound £99 deal. Any thoughts I don't want mail order I just want to pick it up and go tomorrow.
some players you can make reigon free with a code rather than chiping the player, so its best to ask around for one of them, i'll see what i can dig up, but i cant promise i will get nething
I had a quick look @ www.dvdreviewer.co.uk found a couple, I know about the remote hack, I'm not that bothered as its an engagement present for someone.
If you have a Toys R Us near you I saw a reasonable one in there just before Christmas. If not, I think Sainsbury's have one that is ok as well. Shame you don't want mail order though as I got quite a nice one from www.amazon.co.uk a couple of months ago, and their selection isn't too bad. The same with www.empiredirect.co.uk
in our front room we have the LG dvd player that argos is flogging for £130, i kno it is over what you want to spend but it is absoloutly cracking, ours is the previous model taht does not do some of the stuff but it has a pic quality better than some double the price
Mmmmm slinky It was a bit more than what your asking, but mine is Samsung M105 its was £150 about 6-7 months ago. Picture and sound are as sharp as you could want, it was remote hackable straight from the box and it will put a Lian li/coolermaster to shame in the looks department- the thing is just soooo slinky. :dude: Hell- it even says Hello when you switch it on and goodbye when you turn it off As you can probably tell its my baby However you might be able to get a better deal now, (this was a while ago) and I'm not sure whether the firmware in the newer 105's allows you to disable macrovision and is remote hackable
Re: Mmmmm slinky that is a nice player i set one up for a neighbor of mine sa they did dnot know how to wire it up to there tv & i will admit the pic & sound o it is pin sharp
Mitsubishi! Mitsubishi do a region free Playa! I can't remember the model No. but i'll see if i can find out! My brother picked one up! Its down a region 2 but the guy at the store told him it was region free! And it is! We have watched 3 different regions onit no problem!
