Motors I want to know how cars work!
Discussion in 'General' started by Bogomip, 19 Feb 2009.
  1. Stickeh
    Stickeh Help me , Help you.
    20 Jul 2003
    Buy a mini, let it break, take apart offending item, learn about it, fix it.
    3 years ago i hadn't a clue about cars really, i knew basics but not what really goes on... as the mini broke down i picked stuff up, i can change a headgasket and wheelbearings at home, ball joints, cv joints, cv boots, radius arms, fuel pumps, carbs, rockers, rocker clearance.
    My gearbox has just gone, so now this gives me the opportunity to look at wtf is in that box that makes the car go vroom in the first place!
  2. Red 5
    Red 5 What's a Dremel?
    1 Aug 2008
    Fixed. My old tutor was very insistent on it.
    As for learning how cars work, it may depend on whether there are specific parts of a car you want to learn about or the whole thing. Also whether you want to know how something does what it does or why something does what it does. The only website suggestion I can make is Wikipedia.
  3. GreatOldOne
    GreatOldOne Wannabe Martian
    29 Jan 2002
    Ah yes - but it really doesn't have the same ring now, does it. ;)
  4. §§...
    §§... What's a Dremel?
    19 Mar 2003
    this video might be of some use to show how all the parts of the engine fit and work together
  5. itrush07
    itrush07 Minimodder
    28 Nov 2007
  6. C-Sniper
    C-Sniper Stop Trolling this space Ądmins!
    17 Jun 2007
    I think the sad thing is, i can tell you more about how an airplane engine works (both prop and jet) rather than explain a car engine. Airplane engines are much easier to work on too.
